I accidently had my fan profile set to 0rpm while playing no mans sky for about 10 mins. I realized and the tempreture was at 87c and throttling. I quickly put it to 100% speed to cool it off and reset the fan profile. Would that short exposure to high temps damage the card?
R5 5600   Asus ROG Strix RTX2060   B550  Crucial Ballistix 16GB DDR4   Kingston A2000 1TB M.2    Kingston UV400 SSD   NZXT H510 Flow
https://linustechtips.com/topic/751572-safe-rx480-temps/
2 minutes ago, Aytex said:
Not really.
You're fine
Just keep fiddling with the profile until you can get around 60c-80c on load.
The original profile keeps it under 75c. I feel silly for doing that mistake. But I guess the card is designed to prevent damage
https://linustechtips.com/topic/751572-safe-rx480-temps/#findComment-9510698
Just now, Froody129 said:
I did this with my 1060 once and it was sitting at like 92C for a good while. Your card should be fine
Thanks :) hope it does stay fine
https://linustechtips.com/topic/751572-safe-rx480-temps/#findComment-9510699
It's not healthy for the card in the long run, but it's fine for a short period of time. don't worry about it.
it wasn't even that hot. if it had gone up to 95c that would have been dangerous.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/751572-safe-rx480-temps/#findComment-9510717
I would say keep it under 90°C and your safe. prolonged high temps above 85 might cause damage over time but it would take years.
https://linustechtips.com/topic/751572-safe-rx480-temps/#findComment-9510727
