Cpu cooler smells like fire
Go to solution Solved by unseenblade,
okay guys my ram was loose and also some other wire. it stopped the burning smell.
i just want to ask if its possible that loose ram / wire can cause burning? my issue is fixed
I reset my BIOS using the CMOS jumper and after I did that my monitor would not display anything so I reset the bios again and then my CPU Cooler start to smell like fire everytime I turn it on my computer is a little bit over 1 month old and never had any issues like this I'm too scared to turn my computer on do to it probably catching on fire
https://linustechtips.com/topic/745862-cpu-cooler-smells-like-fire/
disassemble, inspect. REMOVE POWER.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
The real question here is what does fire smell like...?
I think you mean smoke...
Make sure there aren't any screws or anything shorting connections on the motherboard, and make sure everything is plugged in securely.
Try cleaning the cooler and surrounding areas off with some canned air.
Just now, unseenblade said:
There's nothing ther I checked everything everything looks clean there's no dust in certain areas this happen after I reset my BIOS twice my Ram starts a smell like burn and my CPU Cooler smells like burn
Mind taking a picture or two (of the motherboard, cpu cooler, and ram) and sending it so we can see?
please tell me you took the plastic off the cooler? some people only notice it after a while but it will go horribly wrong!
You have a lot more issues than just uploading pictures.
Maybe start by giving your parts list otherwise nobody can help.
4 minutes ago, unseenblade said:
I have issues uploading pictures
I'm more curious of how you take pictures of smell.......
