BeQuiet! SilentWings3
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/744792-quiet-120mm-fan/#findComment-9435806
Fractal design, noiseblocker, bequiet.
https://linustechtips.com/topic/744792-quiet-120mm-fan/#findComment-9435849
Bequiet Pure Wings 2 are pretty quiet too and not really expensive, last time i have found them for around 8€
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/744792-quiet-120mm-fan/#findComment-9435854
1 hour ago, Merkey said:
Less than $20 per fan which is around 500 czech crowns.
Can you link us to where you're shopping? What stock fans are you referring to?
https://linustechtips.com/topic/744792-quiet-120mm-fan/#findComment-9436299
I am referring to Zalman Z1 case stock fans and I am buying at www.alza.cz. Not very much to choose from compared to US shops but still good...
https://linustechtips.com/topic/744792-quiet-120mm-fan/#findComment-9438895
Depending on how much you want to spend, some good options include:
Arctic F12: https://www.alza.cz/arctic-f12-120mm-d349024.htm?catid=18849245
Magma Advance: https://www.alza.cz/enermax-magma-advance-d489575.htm?catid=18849245
Slipstream: https://www.alza.cz/scythe-sy1225sl12lm-p-slip-stream-d154214.htm?catid=18849245
NF-S12B: https://www.alza.cz/noctua-nf-s12b-redux-1200-levne-d2177956.htm?catid=18849245
https://linustechtips.com/topic/744792-quiet-120mm-fan/#findComment-9443150
18 hours ago, WoodenMarker said:
Ah, thanks very much, I didnt think you would bother to search something on that website :D. I will choose between those fans because they really seem like the best options
https://linustechtips.com/topic/744792-quiet-120mm-fan/#findComment-9447197
I've heard a lot of good stuff about scythe fans, so i would put a recommendation here.
The arctic fans are good for budgety but can get a little loud if you put them under some load.
Noctuas are gr8 but damn expensive, but if you can pick one up, i'd defo recommend them.
i AM A TASTY NUUUUUB!!!!!
https://linustechtips.com/topic/744792-quiet-120mm-fan/#findComment-9449880
