So, I am going to buy my PC next week...
I chose,
CPU   - Intel core i7-7700k
Mobo - MSI Z270 tomahawk
RAM  - Corsair Vengence 32GB (4x8GB) LPX 3200MHz
Now I am confused because, the cpu says (Memory Types DDR4-2133/2400) amd the Mobo says (anything over 2133 has OC after it up to 3800MHz)... I don't want to over clock... Will i face any issues then....
https://linustechtips.com/topic/744644-do-i-need-to-overclock/
Why are you getting an unlocked CPU and z series mobo if you dont want to OC? Of course, overclocking is unnecessary, but you can buy cheaper parts if you don't want to overclock (7700 non k, non z series board). Memory will automatically be set once you enable XMP in BIOS.
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
https://linustechtips.com/topic/744644-do-i-need-to-overclock/#findComment-9434080
overclocking shouldn't be necessary, because XMP exists.
still though, overclocking is literally just free performance, you already have the parts needed, so why not try it?
https://linustechtips.com/topic/744644-do-i-need-to-overclock/#findComment-9434085
Technically, overclocking is not "free performance."
https://linustechtips.com/topic/744644-do-i-need-to-overclock/#findComment-9434125
well, the parts come at a premium sure, but in this scenario where the parts are already bought i guess it could be clarified as?
https://linustechtips.com/topic/744644-do-i-need-to-overclock/#findComment-9434131
You might just need to set frequency to 3200 in BIOS. It's not that much of an overclock when it comes to RAM.
And you won't have any problems with it.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/744644-do-i-need-to-overclock/#findComment-9434138
The requirement of overclocking is dependent on a number of factors. Since you're buying a CPU with a competent architecture and high clock speeds, I would say that it's not required by any means, but you should test the waters with overclocking, so you can bump the CPU up to that frequency when it's required.
https://linustechtips.com/topic/744644-do-i-need-to-overclock/#findComment-9434141
2 minutes ago, UMxMarky94 said:
depends what your overclocking,
It's never free. You have other factors to consider, like heat and increased power draw.
https://linustechtips.com/topic/744644-do-i-need-to-overclock/#findComment-9434148
I chose,
The 2133/2400 rating for the 7700k is nothing more than Intel telling you that they have verified memory up to 2400 MHz.  The Integrated Memory Controller (IMC) on Kaby Lake is very strong and can run much faster memory than the 2400 MHz rating from Intel suggests.  4000 MHz and higher is very common in dual stick configurations.
The maximum memory speed that you'll be able to achieve is based on how strong your 7700k's IMC is, what your motherboard can support, and the quality/binning of the memory that you purchase.
https://linustechtips.com/topic/744644-do-i-need-to-overclock/#findComment-9434150
I'm referring to energy consumption in general. By overclocking, you are increasing the amount of energy consumed, and the amount of heat produced.
https://linustechtips.com/topic/744644-do-i-need-to-overclock/#findComment-9434151
yes there are trade off but it depends what you count as free.
its free from a cost point of view with graphics cards
also if your doing a light overclock it could be a very very low impact from a heat and power
https://linustechtips.com/topic/744644-do-i-need-to-overclock/#findComment-9434166
I chose,
You won't face any issues even if you don't overclock.
You ram will run at a lower speed ( 2400 mhz ) so it's useless to buy a higher OC ram if you don't plan to overclock, as it will run in 2133 or 2400 at max.
The CPU and MOTHERBOARD are both overclockable parts, you won't have any issues but then again, you are kinda wasting money in buying expansive parts that cost more than normal parts because they are overclockable and not overclocking them makes kind of non sense but its like you want :P
https://linustechtips.com/topic/744644-do-i-need-to-overclock/#findComment-9434283
