Raspberry PI 3 | HOME CINEMA
Solved by Strayuru,
You can use BerryBoot to install a load of different OS' on your Raspberry Pi 3, including Android. Go through those and see which suits your needs best
BerryBoot also makes it SOOO much easier than having to do all the work yourself.
Featured Topics
Od1sseas ·
Posted in Operating Systems2 -
amaliasugar ·
Posted in Graphics Cards0 -
3
Louscou ·
Posted in Troubleshooting3 -
1
nulcow ·
Posted in Laptops and Pre-Built Systems2 -
2
1
SteffanF ·
Posted in New Builds and Planning3
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
