How do you find the frequency of an oscillation from the characteristic equation without solving the whole diffeq?
b = 0
c = 4 pi2
z+ bz + c = 0, z = +- 2i Pi
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/742421-differential-equations-help/
4 minutes ago, wii8cookies said:
2+2=4
Are you positive? Let me count using my fingers.
3 minutes ago, DoctorZeus said:
at least post a picture of the problem
There's no need for a picture of the problem. It's actually a very simple question for anyone who has taken a Differential Equations class.
PSU Tier List | CoC
2 minutes ago, DoctorZeus said:
It's so simple? You solved it then! Yay!!
It's very simple for someone who has taken a diffeq class. I haven't. This is akin to asking how do you find the solutions to something like this: y^2 + 2y + 3 = 0. You just need to know about the quadratic formula and then it's easy.
PSU Tier List | CoC
i tried, but I didn't understand anything of what you said except for the numbers so I wasn't sure what you are looking for. Im just a high school student with education up to alg2, currently studying trig. This is all I was able to come up with. sorry i couldn't help. good luck tho
The imaginary part of the root of the auxiliary equation is the circular frequency, and the real part is the coefficient for the exponential.
You basically just have to convert the root from rads/s to revs/s (Hz).
"Do as I say, not as I do."
-Because you actually care if it makes sense.
Is there really a quadratic formula for *everything? * god damn, and here I am being stumped by adding quad. fractions
- snip-
My brain bits, they're everywhere.
- snip-
33 minutes ago, MrDynamicMan said:
Is there really a quadratic formula for *everything?* god damn, and here I am being stumped by adding quad. fractions.
In this instance he actually is directly solving a quadratic equation.
Perfect, thanks.
PSU Tier List | CoC
@Kumaresh
I figured it out thanks to @Dash Lambda
But you can use the characteristic equation in order to solve oscillating diffeq's.
Given: y''[t] + by'[t] + cy[t] = 0, y[0] = x, y'[0] = z
Then:
Characteristic equation  = z^2 + bz + c = 0. (solve for z-> z1, z2)
GenSol[t] = k1/e^(z1*t) + k2/e^(z2*t)
GenSol'[t] = z1*t * k1/e^(z1*t) + z2*t * k2/e^(z2*t)
Set gensol[0] = y[0] and gensol'[0] = y'[0] and solve for k1 and k2.
Plug k1/k2 back into gensol[t] and then you can plot that as your oscillating solution to the diffeq. So you can see the frequency in the plot, or you can find the frequency from the characteristic equation. So, according to @Dash Lambda if z = 2Pi i, then the frequency would be 2Pi * 1 Rev/2Pi = 1.
PSU Tier List | CoC
No! There isn't! For example, there is no known equation to find the roots of a 5th degree polynomial.
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
13 minutes ago, Kumaresh said:
@djdwosk97 The derivative of gensol[t] looks wrong. Check it again.....
I misstyped typed it, but I wrote it down correctly when I did it.
GenSol'[t] = (-z1 * k1/e^(z1*t)) - (z2 * k2/e^(z2*t))
PSU Tier List | CoC
9 hours ago, Kumaresh said:
Looks like the DE of a damped oscillation... That is above my area of speciality :/ I don't know all the special forms required to solve these second order DE yet...
It's actually undamped. He gives the general form of a damped oscillation, but the damping coefficient is 0.
The characteristic equation of a homogeneous LDE works by assuming a solution can be expressed in the form y = Cert, and since y(n) = rny, you can substitute rn for y(n) to find r. (He used z.)
Per this form, if the root is a real number, the solution is an exponential. If it's complex, the solution is y = Ce(a + bi)t = Ceate(bi)t, which by Euler's identity can be expressed as y = eat(C1sin(bt) + C2cos(bt)).
Therefore, if the real part is 0, as is the case in x2 + c = 0 (where c is a positive constant), eat = 1 and the motion is undamped.
53 minutes ago, Kumaresh said:
@Dash Lambda Thanks for the info :D I didn't pay attention to the coefficients which OP mentioned. I normally use a different method considering it is a homogenous D.E. I thought Euler's identity was e^(ix)=cos(x)+i*sin(x).
That is Euler's identity. Only difference is that the arbitrary coefficients can be complex, so you can make the second coefficient C2 rather than C2i.
What method do you normally use?
What if z = (-2.85 + 3.46085i) and (-2.85 - 3.46085i)? Would it be: 3.46085/2Pi - 2.85 = 2.3~?
PSU Tier List | CoC
No, the real part governs the damping, and damping doesn't change the frequency of oscillation.
When the root is complex, the exponential becomes e(a + bi)t, which you separate into eate(bi)t. When you substitute using Euler's identity, you only replace the exponential containing the imaginary number, so only b influences the frequency.
