runing Ethernet cable outside
6gv6hbbuhh
i want to run Ethernet cable outside to a shed so it has to go on the roof of three story house down the house and across the wall should i put the Ethernet cable through a  garden hoes to protect it from the sun and rain
you can buy ethernet cableing that is "exterior" or outside rated
I lurk a lot
Agree. Easiest option, if you really need a wired connection.
Although garden hose or PVC pipe might be cheaper.
Does you mum know you're here?
300m of outside ethernet cable is £50 exactly the same price as normal c5e
I lurk a lot
You should use outdoor rated cable ran inside conduit.
Conduit protects the cable from physical damage.
The outdoor rated cable should be gel-filled with a tougher jacket. This protects the wires from water that will inevitably get inside the conduit. The filling prevents condensation inside the cable itself.
and outside cable is shielded. so a shovel will nog kill the cable in one blow. ( i have experience)
