Hey guys I own a MSI Gp 2 Qe and I want to change my CPU for a faster one with at least 4 cores, so in few words what CPU would you recommend me and why. Thanks.
Actual CPU  Intel I5 4210H
Chipset  Intel HM86
Memory   2 x DDR3L-1600 MHz,max 16GB
Display   17.3" FHD(1920x1080) Anti-Glarere
Graphics  NVIDIA GeForce 940M 2 Gb
I don't really think that you need much more information than that so if I miss something tell me thanks!
https://linustechtips.com/topic/736809-help-changing-cpu/
Chipset  Intel HM86
A laptop? You can't change a CPU in a laptop.
https://linustechtips.com/topic/736809-help-changing-cpu/#findComment-9350736
The i5 4210H is listed as a BGA1364 socket CPU, meaning it is ball grid array which is soldered to the motherboard. You won't be able to change it.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
https://linustechtips.com/topic/736809-help-changing-cpu/#findComment-9350840
You can in some.  I've seen a fair number that weren't soldered on.  I've even got a back of spare mobile processors in my desk.
Make sure to quote or tag me (@JoostinOnline) or I won't see your response!
PSU Tier List  |  The Real Reason Delidding Improves Temperatures"2K" does not mean 2560×1440
https://linustechtips.com/topic/736809-help-changing-cpu/#findComment-9350843
1 minute ago, Antony Leung said:
Anyways, trying to change something for a laptop is very difficult and hard to find with the exception of the RAM. that's the only thing easy to do.
Just build a budget pc instead, and get better performance overall.
https://linustechtips.com/topic/736809-help-changing-cpu/#findComment-9351225
