Hello , any one know how to fix or a reason behind why my background randomly goes black removing all icons and the task bar but i still can access programs that are currently open by alt tabbing ? As well as that Steam and other programs randomly crash with sometimes a windows notice saying 'This program cannot be run' or other-times nothing at all and the whole screen just randomly reloads .
My OS is currently running on a SSD 150gb and all my other programs are on a 1TB Hybrid Hard Drive , i recently defragged to fix an IO error about a week ago which seemed to restore some stability, however other problems are now occurring . Is the Hard Drive dieing  , lacking power or overheating :P ? Any one know an explanation . Thanks !
Edit : As i'm making this all additionally programs on the secondary hard drive crashed and the hard drive is no longer visible on the 'This Pc' section . RIP.
https://linustechtips.com/topic/735619-pc-problem-p/
Not sure how much wattage do you have?
MY MAIN BUILD AT FATHERS HOUSE!
CPU: AMD FX-8300 3.3GHz 8-Core Processor CPU COOLER:  Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
Motherboard: Gigabyte GA-970A-DS3P ATX AM3+ Motherboard
RAM: 32gb ddr3
Hard Drive:  Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Graphics Card:  MSI Radeon RX 470 DirectX 12 Radeon RX 470 ARMOR 4G OC 4GB 256-Bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
Case: Rosewill TYRFING ATX Mid Tower Case
Network Adapter:  TP-Link TL-WN781ND PCI-Express x1 802.11b/g/n Wi-Fi Adapter
Case Fans:  Corsair Air Series AF140 Quiet Edition 67.8 CFM 140mm Fan (PLUS THE STOCK CASE FAN)
Monitor:  Asus VG248QE 24.0" 1920x1080 144Hz Monitor
Keyboard:  Thermaltake CHALLENGER PRIME Wired Gaming Keyboard
Mouse:  MSI Interceptor DS B1 Wired Optical Mouse
Speakers: Logitech Z200 0W 2ch Speakers
https://linustechtips.com/topic/735619-pc-problem-p/#findComment-9338703
1 minute ago, Roadrunt said:
750w
What are your specs
RAM: 32gb ddr3
https://linustechtips.com/topic/735619-pc-problem-p/#findComment-9338710
CPU : Fx 8350 Vishera Black Edition
Cooling : h50 corsair water cooling
Power-supply : 750w Corsair Power supply
GPU : XFX R9 380 4gb
Motherboard : gigabyte ga-78lmt-usb3
Ram : 16GB
SSD : 150gb
HardDrive : 1TB Hybrid
Fans : 4 (including water cooling fan)
https://linustechtips.com/topic/735619-pc-problem-p/#findComment-9338730
When the task bar disappears it usually means the Windows Explorer crashed. Run som disk health checks on the secondary drive...  Sounds like it may be defective.  In all honesty it also sounds like you could do with a clean install of Windows.
https://linustechtips.com/topic/735619-pc-problem-p/#findComment-9338735
9 minutes ago, Roadrunt said:
I did a clean install when i first put the SSD in 3 weeks ago or so now , probably just defective hard drive had it a few years.
Disconnect the hdd and see if the problem continues
https://linustechtips.com/topic/735619-pc-problem-p/#findComment-9338780
