So I was looking to make a overkill NAS of somewhere close to 16TB in Raid 0 (Ballin and risky but its what I want.)
It will run some linux distro which I'll figure out later but I was wondering the following;
1. RAM requried for 16tb ext4 share
2. PSU (for 8x2tb drives)
3. HBA card suggestions (Just hba, no raid features needed.)
https://linustechtips.com/topic/733437-ltt-style-nas-build/
Linus style, so you want to lose your data?
don't use raid 0, just don't(unless you have HA or very often syncs)
1. 4gb should be fine, you need very little ram(but id use raid 0 in btrfs)
2. 200w should be fine with a lower power cpu
3. lsi 9207 8i? used dell h300?
https://linustechtips.com/topic/733437-ltt-style-nas-build/#findComment-9315084
2 minutes ago, strk1204 said:
The plan was a 16TB raid 0 server then a second server which will be slower, but handle backups. Linus style exactly.
what network speed do you have anyways. You probably won't even notice the speed difference between 5 and 0
https://linustechtips.com/topic/733437-ltt-style-nas-build/#findComment-9315108
1 minute ago, strk1204 said:
Whats the write speeds like on RAID 60?
more than gigabit, so it doesn't matter(normally 300+ with that drive count)
Don't run 60 with 8 drives, run 10, you have the same usable space.
Id still run 5 or 6
https://linustechtips.com/topic/733437-ltt-style-nas-build/#findComment-9315148
Which option would provide the best read and write speeds.
10. it is basicly 4 drives in raid 0 with a mirror image. so reads are 8x a single drive and writes are 4x.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/733437-ltt-style-nas-build/#findComment-9315157
your on gigabit, it doesn't matter, You will be network limited in any drive config, even a single drive is faster than your network.
Id personally go raid 5 or 6 depending on how good the drives are
What OS?
What are you using for raid?
https://linustechtips.com/topic/733437-ltt-style-nas-build/#findComment-9315158
Raid 5 and 6 is still faster in sequential because you can read for 6 or 7 drives at once.
Raid 10 is only faster for random iops, Its normally slower for sequential
https://linustechtips.com/topic/733437-ltt-style-nas-build/#findComment-9315161
no with raid 10 all drives can be read from and half can be written to. it should be faster in any way.
https://linustechtips.com/topic/733437-ltt-style-nas-build/#findComment-9315167
2 minutes ago, Electronics Wizardy said:
with 8 dries you have the space of
7 usable with raid 5(and 4)
6 usable with raid 10
4 usable with 10
I didn't want to go with ZFS because of the overhead and system requirements. 1gb ram per 1TB + some more for OS.
https://linustechtips.com/topic/733437-ltt-style-nas-build/#findComment-9315181
