Samsung 960 EVO vs PRO?
Go to solution Solved by RadiatingLight,
I would go for the EVO.
PRO has a longer warranty, longer MTBF, and better read/write speeds, but IOPS are essentially the same, so you won't notice any difference unless you are copying hundreds of gigabytes.
Realistically would I be able to see any real world performance improvements between these two SSDs? Im building a super high performance small form factor PC and if there isn't a noticeable benefit to going with the PRO, i'd just save the money and buy an EVO. Capacity is 500GB if that matters.
https://linustechtips.com/topic/733256-samsung-960-evo-vs-pro/
Price difference?
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
https://linustechtips.com/topic/733256-samsung-960-evo-vs-pro/#findComment-9312967
Difference in price doesnt justify the diff in performance. I ended up just getting a 960evo.
Windows 10 Edu | Asus ROG Strix X570-F Gaming | Ryzen 9 3950x | 4x 16GB G.Skill Trident Z RGB| ROG Strix GeForce® RTX 2080 SUPER™ Advanced edition | Samsung 980 PRO 500GB + Samsung 970 Evo Plus 2TB + 8TB Seagate Barracuda | EVGA Supernova 650 G2 | Alienware AW3418DW + LG 34uc87c + Dell u3419w | Asus Zephyrus G14
https://linustechtips.com/topic/733256-samsung-960-evo-vs-pro/#findComment-9312972
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/733256-samsung-960-evo-vs-pro/#findComment-9313006
2 minutes ago, Aivex_Someone said:
$249.99 USD - EVO
$329.99 USD - PRO
Neither!!! You could get twice the capacity for that kind of money!
http://pcpartpicker.com/product/bh38TW/crucial-mx300-11tb-25-solid-state-drive-ct1050mx300ssd1
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/733256-samsung-960-evo-vs-pro/#findComment-9313008
3 minutes ago, Aivex_Someone said:
$249.99 USD - EVO
$329.99 USD - PRO
Get the EVO. The Pro isn't worth $80 more...
https://linustechtips.com/topic/733256-samsung-960-evo-vs-pro/#findComment-9313011
It's not about capacity, im looking specifically for an NVME M.2 2280 spec drive. That's a sata III.
https://linustechtips.com/topic/733256-samsung-960-evo-vs-pro/#findComment-9313020
The main benifit of the Pro version is the MLC NAND flash over the TLC stuff on the EVO which helps with durability (number of writes) if you are going to really hammer your drive. In most cases the regular EVO is more than enough for regular users.
https://linustechtips.com/topic/733256-samsung-960-evo-vs-pro/#findComment-9313022
Thanks for the feedback! Gonna go with the evo then.
https://linustechtips.com/topic/733256-samsung-960-evo-vs-pro/#findComment-9313024
BEHOLD!!!!! 8 times the capacity for less than half the money!!!!!!
https://www.newegg.com/Product/Product.aspx?Item=9SIA5AD5740811
https://linustechtips.com/topic/733256-samsung-960-evo-vs-pro/#findComment-9313075
No big deal. The MX300 has an M.2 2880 version for almost nothing more. http://pcpartpicker.com/product/RKhj4D/crucial-mx300-11tb-m2-2280-solid-state-drive-ct1050mx300ssd4
The difference between the M.2 960 EVO and MX300 2.5 is negligible to the vast majority of users. The difference between either of those and that hard drive? Colossal. Don't pretend that the jump from an MX300 to a 960 EVO is even close to the improvements you get when you go from a 7200RPM HDD to an MX300. Sure, the MX300 might have 1/4th the write speeds on paper, but it's already so fast that a much faster SSD won't make a night-and-day difference - nowhere near the upgrade from an HDD to any modern SSD. 500-600 MB/s is still incredibly fast.
Capacity determines the amount of data you can store on an SSD for faster access, and the amount of programs you can install on an SSD for faster launch times. If you're a gamer and want to play triple-A titles, you can probably have about five installed on a 500GB SSD, with not a ton of space left over for other programs. Keeping 20% capacity free is a general rule of thumb to avoid choking the performance of your drive. If you want to store media in addition to that, you'll need to invest in a mass-storage solution; an HDD.
However, a 1TB drive is more than enough for a lot of things. I have weeks of recorded lossless audio from my rehearsals and audition tapes, six games installed, one of which is a heavily modded SKyrim, several editing programs, and a lot of stored video rips (backups from my DVD collection), as well as a gargantuan 80GB music library of over 7,000 songs. 500GB is definitely a point where you can manage without another drive, but a 1TB drive essentially ensures that, unless you plan to have a ton of 4k video footage on hand at all times or something similar.
https://linustechtips.com/topic/733256-samsung-960-evo-vs-pro/#findComment-9313374
However, a 1TB drive is more than enough for a lot of things. I have weeks of recorded lossless audio from my rehearsals and audition tapes, six games installed, one of which is a heavily modded SKyrim, several editing programs, and a lot of stored video rips (backups from my DVD collection), as well as a gargantuan 80GB music library of over 7,000 songs. 500GB is definitely a point where you can manage without another drive, but a 1TB drive almost completely ensures that.
The one you linked is also a Sata interface drive, not NVME.
https://linustechtips.com/topic/733256-samsung-960-evo-vs-pro/#findComment-9313381
Indeed. If the interface is that important to you, then sure, get the EVO. The benefits of the Pro are that its NAND is configured to run in MLC, which is far better for longevity. MLC can withstand more write cycles, as there are less packets of data per cell at a time. More on this here-
That being said, the improvement in performance isn't anything to write home about.
I know that it's a SATA interface drive. My point was to highlight the benefits of a higher capacity drive over a superior interface and better performance.
https://linustechtips.com/topic/733256-samsung-960-evo-vs-pro/#findComment-9313404
This. The MX300 uses the same interface as and is closer in speed to a HDD than the 960.
https://linustechtips.com/topic/733256-samsung-960-evo-vs-pro/#findComment-9313409
I'm aware. However, it's still more than fast enough for the vast majority of users, and provides twice the capacity at the same price - less if you compare it to the 960 Pro. The purpose of my post was to highlight the advantages of that much more capacity.
I linked the M.2 MX300 SSD in case he needed it in that form factor specifically.
https://linustechtips.com/topic/733256-samsung-960-evo-vs-pro/#findComment-9313422
