K just a random thought, but like what if all the cables in your pc were fiber optic cables? Because fiber optics transmit light, you would put the cables in a place where you can see it, instead of hide it behind the back panel. And fiber optic cables are faster too, right? I know they obviously don't make fiber optic sata cables, but what do you think if they did? Thoughts on the idea?
linus sex tips
https://linustechtips.com/topic/730437-fiber-optic-pc-cables/
You wouldn't see squat because you cannot have fiber optic cables in the open, that's not how it works, and even if you could it would all be red light.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/730437-fiber-optic-pc-cables/#findComment-9282319
Fiber optics can be used for any kind of data transfer really. The main issue though is that fiber optics cannot transfer power so that is why we dont see it everywhere. That and most fiber optic cables are far easier to break than traditional copper cables.
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
https://linustechtips.com/topic/730437-fiber-optic-pc-cables/#findComment-9282329
1 minute ago, wii8cookies said:
would it be any faster?
No. The cable's max theoretical bandwidth would be much faster, but the controller chips would not be. Likewise, it also wouldn't be SATA in the optical portion because SATA is specifically a physical interface over copper.
https://linustechtips.com/topic/730437-fiber-optic-pc-cables/#findComment-9282338
