Water Coolant Color
Solved by W-L,
2 minutes ago, dmoney1942 said:Okay thats my plan because it took 3 months for the coolant to change to this blueish color. I will flush the loop with distilled water because i do not want to damage the other parts of the loop with the vinegar. My question is how long to run the pump for each flush.
Give it at least a good 10-15 mins to circulate everything around, that should clear out any of the previous fluid after a few rinses.
