Which cooler will work better?
most likely wont outperform it, but perform similarly. If you don't have an evo just use the sythe and save for a water cooler or smthn. If you already have the evo just keep it.
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
I achieved max temps of about 55°C AIDA64 stress test on a Intel Xeon E5 2670 @ 3.00GHz using the Coolermaster 212 EVO with the fan plugged directly into +12V. Though I haven't the other cooler to compare it to.
5 minutes ago, Mooshi said:
212 evo is donezo. The Cryorig H7 is better from aesthetic to size to performance.
When you say "size" it's actually larger (thicker in particular) this may limit motherboard compatibility and may cause other clearance issues in comparison to the 212 EVO. If it fits the board though then yeah go for it in place of the 212 EVO.
16 minutes ago, D148xZ said:
G3258, I'm planning on maybe upgrading but this thing might get some extra mhz on it
omg dude then its honestly whichever one you want that looks good
or for me its whichever fan runs more silent
either will cool an overclocked g3258 with no issues
Photography / Finance / Gaming
Shouldn't be an issue for majority of boards tbh. Works fine for my itx rig :P
The cooler specs say it supports up to LGA775 sockets. And being such budget purchase, getting mounting kit would be pointless. I hope you can ghetto it on nicely.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
