Yes. The PCIe revision goes unnoticed to multi-GPU setups, as long as the necessary lanes are there.
SLI won't be happy with PCIe 3.0 4x, even though it will work fine with PCIe 2.0 8x, which has the same bandwidth. As long as the physical lanes are there.
"Rawr XD"
https://linustechtips.com/topic/726377-mouthebourd-help/#findComment-9243695
20 minutes ago, joshfrog said:
correct me if im wrong but isnt pci-e 3.0 8x the same bandwidth as pci-e 2.0 16x?
yep
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/726377-mouthebourd-help/#findComment-9243750
Yes.
https://linustechtips.com/topic/726377-mouthebourd-help/#findComment-9244135
On 1/21/2017 at 9:02 AM, coffee boy 200 said:
hi my motherboard runs at pcie 2 x16 and my graphics card runs at pcie 3.0 x8
will it work  :D:D
Threads merged. No need to make multiple threads about the same question.
If you need help with your forum account, please use the Forum Support form !
https://linustechtips.com/topic/726377-mouthebourd-help/#findComment-9244280
