Posted January 16, 2017 Ok I just need to get this straight. Does this fan hub https://www.amazon.com/dp/B00VNW556I/ref=twister_B01N4K63T8?_encoding=UTF8&th=1 connected to these fans http://noctua.at/en/products/product-line-redux/nf-s12b-redux-1200-pwm Connect to the motherboard and allow software control? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 16, 2017 5 minutes ago, be_x said: Ok I just need to get this straight. Does this fan hub https://www.amazon.com/dp/B00VNW556I/ref=twister_B01N4K63T8?_encoding=UTF8&th=1 connected to these fans http://noctua.at/en/products/product-line-redux/nf-s12b-redux-1200-pwm Connect to the motherboard and allow software control? Yes, but controlling with a software such as SpeedFan will make all of them the same speed. And those fans will work with the hub Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 16, 2017 Yes, but the software control will only control the hub and rpm will be same on the fan connected to it. If you want individual control of the fan you will have look at other option such as corsair commander or nxzt fan hub or something along those lines which allow individual control on fan hub through a usb 2.0 connector. Don't you have enough fan headers on your current motherboard? You could also try a 2 way splitter. Magical Pineapples
