Panasonic Lumix G7 and G85 body, same?
Solved by AkiraDaarkst,
2 hours ago, dante04317 said:I'm looking forward to buying a cage for The Panasonic G85, and I found a cage which is for g7, will it work with the G85
http://www.smallrig.com/SmallRig-Panasonic-G7-Formfitting-Cage-1779.html
A cage that is still in the design stage
http://www.smallrig.com/SMALLRIG-Cage-for-Panasonic-Lumix-DMC-G85-G80-1950.html
The best thing you can do is to contact them to be sure. They actually provide feedback to their customers and potential customers fairly quickly and listen to feedback from customers to improve their designs.
