Need help building my gaming PC.
Go to solution Solved by The Sloth,
use pc partpicker
2 minutes ago, Alexandros said:
Ok i got what u asked me an im going for a micro atx motherboard
Wait wait, im working on it
The geek himself.
PSU: Seasonic S12II 430B
Case: Whichever is cheap to you and look good to you, doesn't matter much
You think you could try this? if not ill keep working on it.
PCPartPicker part list: https://pcpartpicker.com/list/8JkhYr
Price breakdown by merchant: https://pcpartpicker.com/list/8JkhYr/by_merchant/
CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor  ($179.33 @ OutletPC)
Motherboard: ASRock H110M-HDS Micro ATX LGA1151 Motherboard  ($46.99 @ SuperBiiz)
Memory: Corsair Vengeance LPX 8GB (1 x 8GB) DDR4-2400 Memory  ($49.99 @ NCIX US)
Storage: Sandisk SSD PLUS 120GB 2.5" Solid State Drive  ($44.99 @ Best Buy)
Storage: Western Digital AV-GP 1TB 3.5" 5400RPM Internal Hard Drive  ($43.50 @ Amazon)
Video Card: Asus Radeon RX 460 2GB Dual OC Video Card  ($94.99 @ SuperBiiz)
Total: $459.79
Generated by PCPartPicker 2017-01-17 20:44 EST-0500
The geek himself.
This is probably your best route
PCPartPicker part list: https://pcpartpicker.com/list/3Nyv2R
Price breakdown by merchant: https://pcpartpicker.com/list/3Nyv2R/by_merchant/
Power Supply: EVGA 430W 80+ Certified ATX Power Supply  ($31.49 @ OutletPC)
Total: $446.29
Generated by PCPartPicker 2017-01-17 20:45 EST-0500
The geek himself.
CPU: Intel Pentium G4560 3.5GHz Dual-Core Processor  ($75.00 @ B&H) dual core with hyperthreading.
Memory: Corsair 8GB (1 x 8GB) DDR4-2133 Memory  ($44.38 @ Newegg Marketplace)
Storage: Seagate Pipeline HD 2TB 3.5" 5900RPM Internal Hard Drive  ($46.50 @ Amazon)
Video Card: XFX Radeon RX 470 4GB Triple X Video Card  ($164.99 @ Amazon)
Case: Rosewill FBM-05 MicroATX Mini Tower Case  ($24.99 @ Newegg) versa n21 if you can spend abit more.
Power Supply: EVGA 450W 80+ Bronze Certified ATX Power Supply  ($38.49 @ SuperBiiz) not the best but more than enough.
Total: $441.34
Generated by PCPartPicker 2017-01-17 20:47 EST-0500
Total: $441.34
Why do yall always cheap out on parts.
The geek himself.
says the guy getting the W1 for the psu.
Well, you cheap put on PSU...
The PSU is not that bad, my friend has one, works fine, not sure why yall always get all pantie about it.
The geek himself.
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story3&reid=431
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story4&reid=431
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story5&reid=431
i'm fine with it on a cheap iGPU HTPC with a pentium, not with an i5 and rx 460.
http://www.hardocp.com/article/2015/02/19/evga_430w_power_supply_review/9#.WH7Lk_l94uU
