Posted January 9, 2017 I live in India. I will mention price in Indian rupees as well as in USD (prices are directly taken from Amazon) 1) MSI GeForce GTX 1050TI 4GB DDR5 - ₹16,300($239.28) 2) GIGABYTE GeForce GTX 1060 G1 Gaming 3GB - ₹17668.58($259.37) 3) MSI GAMING GeForce GTX 1060 3GB VR READY - ₹16722.15($245.48) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 9, 2017 whats the rest of the system? "The of and to a in is I that it for you was with on as have but be they" Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 9, 2017 I'd actually get an RX 480. it is a better value and can play most games in 1080p with ultra settings. It is around $200 for the cheapest models "You think your Commodore 64 is really neato! What kind of chip you got in there a Dorito?" -Weird Al Yankovic, All about the pentiums PC 1(Lenovo S400 laptop): CPU: i3-3217u SSD: 120gb Super Cache mSATA SSD HDD: Random seagate 5400rpm 500gb HDD RAM: 8GB Crucial DDR3-SODIMM OS: Windows 10 education PC 2(2014 Mac Mini): CPU: i5-4260u HDD: 5400rpm 500gb RAM: 4gb DDR3 (soldered on ) OS: MacOS Sierra/Windows 10 pro via bootcamp Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 9, 2017 Assuming you plan on upgrading later and Dont plan on gaming on AAA games on ultra then i would go with the 1050TI (or 1060 on a good deal) for now Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 9, 2017 If you can't work a 6gb 1060 in then go with the msi, no point in paying a ton more for an extra fan. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 9, 2017 Since u are on a buget i think you are not going to "upgrade" in the next year or so. (I was in same situation) I think the MSI one is good , and 3Gb of ram is ok , few games need more than 3gb ram at 1080p. And one fan will work good, i have a gigabyte gtx 1060 3gb itx with one one fan and the temps are great. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 9, 2017 10 minutes ago, AA-RonRosen said: I'd actually get an RX 480. it is a better value and can play most games in 1080p with ultra settings. It is around $200 for the cheapest models I'd also do that but from what I learned on this forum is that in India AMD is overpriced as fuck. GTX 1060 3GB for 245$ imo out of those 3, but if OP can splash more for the 1060 6GB then that'd be a better idea. CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 9, 2017 RX 470 4GB | CPU: Core i7-8700K @ 4.89ghz - 1.21v | Motherboard: Asus ROG STRIX Z370-E GAMING | CPU Cooler: Corsair H100i V2 | | GPU: MSI RTX 3080Ti Ventus 3X OC | RAM: 32GB T-Force Delta RGB 3066mhz | | Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 2 VR Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 9, 2017 I'd get the MSI 1050Ti because it simply has more VRAM available, but it has less clock speed though. But you can always push that up with MSI afterburner a bit. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 9, 2017 3 minutes ago, MrHomes said: I'd get the MSI 1050Ti because it simply has more VRAM available, but it has less clock speed though. But you can always push that up with MSI afterburner a bit. The 1060 3GB performs within 5% of the 1060 6GB. The GTX 1050 Ti is far slower than either of them. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 11, 2017 Author On 1/9/2017 at 8:33 PM, Ostwind said: whats the rest of the system? i3 h110-s2 motherboard hyperx fury 8gb Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 11, 2017 Author On 1/9/2017 at 8:45 PM, Morgan MLGman said: I'd also do that but from what I learned on this forum is that in India AMD is overpriced as fuck. GTX 1060 3GB for 245$ imo out of those 3, but if OP can splash more for the 1060 6GB then that'd be a better idea. no money boss ? i have a tight budget bro!! cant opt out for a 6 gb one Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 11, 2017 Price of RX 470/480 in your country? SFF-ish: Ryzen 5 1600X, Asrock AB350M Pro4, 16GB Corsair LPX 3200, Sapphire R9 Fury Nitro -75mV, 512gb Plextor Nvme m.2, 512gb Sandisk SATA m.2, Cryorig H7, stuffed into an Inwin 301 with rgb front panel mod. LG27UD58. Aging Workhorse: Phenom II X6 1090T Black (4GHz #Yolo), 16GB Corsair XMS 1333, RX 470 Red Devil 4gb (Sold for $330 to Cryptominers), HD6850 1gb, Hilariously overkill Asus Crosshair V, 240gb Sandisk SSD Plus, 4TB's worth of mechanical drives, and a bunch of water/glycol. Coming soon: Bykski CPU block, whatever cheap Polaris 10 GPU I can get once miners start unloading them. MintyFreshMedia: Thinkserver TS130 with i3-3220, 4gb ecc ram, 120GB Toshiba/OCZ SSD booting Linux Mint XFCE, 2TB Hitachi Ultrastar. In Progress: 3D printed drive mounts, 4 2TB ultrastars in RAID 5. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 11, 2017 Author 1 minute ago, Phate.exe said: Price of RX 470/480 in your country? rx 480 = ₹45000 ($658.349) rx 470= ₹53975 ($789.65) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 11, 2017 Author 1 minute ago, Buddy6900 said: rx 480 = ₹45000 ($658.349) rx 470= ₹53975 ($789.65) rx470 = my whole builds cost Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 11, 2017 On 1/10/2017 at 4:10 AM, EminentSun said: If you can't work a 6gb 1060 in then go with the msi, no point in paying a ton more for an extra fan. 3GB 1060 has a bit more than an extra fan... http://gpu.userbenchmark.com/Compare/Nvidia-GTX-1060-3GB-vs-Nvidia-GTX-1050-Ti/3646vs3649 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 11, 2017 41 minutes ago, Prqnk3d said: 3GB 1060 has a bit more than an extra fan... I know, I meant the 1060 3gb MSI with only one fan vs the Gigabyte 1060 with 2. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 11, 2017 6 hours ago, Buddy6900 said: rx 480 = ₹45000 ($658.349) rx 470= ₹53975 ($789.65) 6 hours ago, Buddy6900 said: rx470 = my whole builds cost What the actual fuck. I paid $165-ish for mine. SFF-ish: Ryzen 5 1600X, Asrock AB350M Pro4, 16GB Corsair LPX 3200, Sapphire R9 Fury Nitro -75mV, 512gb Plextor Nvme m.2, 512gb Sandisk SATA m.2, Cryorig H7, stuffed into an Inwin 301 with rgb front panel mod. LG27UD58. Aging Workhorse: Phenom II X6 1090T Black (4GHz #Yolo), 16GB Corsair XMS 1333, RX 470 Red Devil 4gb (Sold for $330 to Cryptominers), HD6850 1gb, Hilariously overkill Asus Crosshair V, 240gb Sandisk SSD Plus, 4TB's worth of mechanical drives, and a bunch of water/glycol. Coming soon: Bykski CPU block, whatever cheap Polaris 10 GPU I can get once miners start unloading them. MintyFreshMedia: Thinkserver TS130 with i3-3220, 4gb ecc ram, 120GB Toshiba/OCZ SSD booting Linux Mint XFCE, 2TB Hitachi Ultrastar. In Progress: 3D printed drive mounts, 4 2TB ultrastars in RAID 5. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 11, 2017 6 hours ago, Buddy6900 said: rx 480 = ₹45000 ($658.349) rx 470= ₹53975 ($789.65) Are you sure?https://gyazo.com/4e3d7c5b2f686751efa817ea22fb94c6http://www.amazon.in/Gigabyte-Radeon-Gaming-Graphics-GV-RX470G1GAMING-4GD/dp/B01JNTXM2Q/ref=sr_1_1?ie=UTF8&qid=1484176494&sr=8-1&keywords=rx470 PC - CPU Ryzen 5 1600 - GPU Power Color Radeon 5700XT- Motherboard Gigabyte GA-AB350 Gaming - RAM 16GB Corsair Vengeance RGB - Storage 525GB Crucial MX300 SSD + 120GB Kingston SSD PSU Corsair CX750M - Cooling Stock - Case White NZXT S340 Peripherals - Mouse Logitech G502 Wireless - Keyboard Logitech G915 TKL - Headset Razer Kraken Pro V2's - Displays 2x Acer 24" GF246(1080p, 75hz, Freesync) Steering Wheel & Pedals Logitech G29 & Shifter Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 11, 2017 voted for the Gigabyte cuz i like them but get one of the 1060s, or if you can find the 470 @RKRiley posted a picture of get that I spent $2500 on building my PC and all i do with it is play no games atm & watch anime at 1080p(finally) watch YT and write essays... nothing, it just sits there collecting dust... Builds: The Toaster Project! Northern Bee! The original LAN PC build log! (Old, dead and replaced by The Toaster Project & 5.0) Spoiler "Here is some advice that might have gotten lost somewhere along the way in your life. #1. Treat others as you would like to be treated. #2. It's best to keep your mouth shut; and appear to be stupid, rather than open it and remove all doubt. #3. There is nothing "wrong" with being wrong. Learning from a mistake can be more valuable than not making one in the first place. Follow these simple rules in life, and I promise you, things magically get easier. " - MageTank 31-10-2016 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 11, 2017 I'm truly surprised that anyone would recommend the 1050ti given how big the performance difference is. At 50% or more faster it's a no-brainer. CPU - Ryzen Threadripper 2950X | Motherboard - X399 GAMING PRO CARBON AC | RAM - G.Skill Trident Z RGB 4x8GB DDR4-3200 14-13-13-21 | GPU - Aorus GTX 1080 Ti Waterforce WB Xtreme Edition | Case - Inwin 909 (Silver) | Storage - Samsung 950 Pro 500GB, Samsung 970 Evo 500GB, Samsung 840 Evo 500GB, HGST DeskStar 6TB, WD Black 2TB | PSU - Corsair AX1600i | Display - DELL ULTRASHARP U3415W | Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
