I recently moved in to my house, new to me but build over 20 years ago. This is my first winter in it, and I notice that every time the heater turns on the screen goes blank for a second. This only happens on my computer,  I'm using a tv for a monitor. The tv is also used with an xbox and i never had this issue with either one of them only my computer. I think what is happening is that the heater for fraction of a second" to start up" pulls to much electricity and for that second the computer lags a bit. Idk I'm not Tesla, but with that logic would a back up power supply, like a battery back up supply fix this issue. one that charged a batter an only went to aux power"battery pack" when the power lvls dropped. I believe they use these in server rooms and the brand I'm most familiar with is APC. I wouldn't need an industrial back up power supply only one that would keep a constant flow of electricity to my computer. Any thoughts or ideas would greatly be appreciated.
Motherboard : MSI 170a M5
Cpu : Intel 6600k
Gpu : Red Devil r480 8g
Ram : 2x4g g.Skill 3200mhz C16
Hard drive : 500g 7200rpm,3tb,2tb all three different brands using 6gb/s sata III
SSD/Nvme: Intel 600p 512gb
https://linustechtips.com/topic/719013-apc-power-supply-back-up/
20 years ago seems pretty recent to me, but some devices (as electric heaters) can introduce a lot of problems. You should use a dedicated high amperage circuit for such devices to avoid overloading your wiring.
But, if you don't want to do that, a simple UPS of any brand will most certainly solve your problems. APC is fine :)
Ryzen 5 5600, 32GB DDR4, GTX 3070Ti, Acer Predator x34
InWin 901
https://linustechtips.com/topic/719013-apc-power-supply-back-up/#findComment-9158822
