4 minutes ago, Electronics Wizardy said:
why sli, id just get a single gtx 1070 or 1080.
980 even does 1440p in most games nicely.
Source: I own a 980 G1 Gaming and it's run every game I throw at it, at high settings. Except Arma 3. Because R.I.P performance in Arma
That time I saved Linus' WiFi pass from appearing on YouTube:
A sudden Linus re-appears : http://linustechtips.com/main/topic/390793-important-dailymotion-account-still-active/
https://linustechtips.com/topic/718017-sli-help/#findComment-9146603
1070/980/980ti will run 1440P comfortably. AMD 480 8gb would be fine also. For 4k better to go with a strong card so you can SLI later when games are harder to run at that res, so a 1080 for now
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/718017-sli-help/#findComment-9146605
Just now, Tedster said:
And be a hassle, and draw more power...
And no further expansion (PCIE sound card, storage, USB, 10Gb nic, Tv-Tuner, Raid)
https://linustechtips.com/topic/718017-sli-help/#findComment-9146613
7 minutes ago, Unfamiliar said:
Whats the cheapest graphics card that is sli ready that is able to run 4k graphics when put together? Or at least 1440p. Thanks
GTX 970. But, I do NOT recommend it.....
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
https://linustechtips.com/topic/718017-sli-help/#findComment-9146618
1 minute ago, App4that said:
No, and yes. But that's your fault for having a weak sauce power supply. Your power supply even lift Bro?
Greater undesired heat output into the room would only be helped slightly by having a very nice power supply...
Sig under construction.
https://linustechtips.com/topic/718017-sli-help/#findComment-9146627
What hassle? Plug em in, use the sli bridge and play. Very few games (big games anyway) have zero SLI support. I SLI'D (cant speak for crossfire) 2x 970's for around 17 months and only Just Cause 3 was an issue out of around 80 + games. Power shouldn't be a concern, if it is buy a console, PC's will always use more. Heat, well ye, I was on water
Ryzen Ram Guide
https://linustechtips.com/topic/718017-sli-help/#findComment-9146628
It would still consume less power than a single R9 Fury though xD
https://linustechtips.com/topic/718017-sli-help/#findComment-9146638
Just now, Unfamiliar said:
Great no one can give an answer around here. Great comments guys!
Basically
Get an RX 480 and leave it at that, it can do med settings just fine.
Get a 1070 if you can spend more.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/718017-sli-help/#findComment-9146640
If you want a cheap card that can do 4K when in SLI, get the GTX 970. It costs around $240 rn....
https://linustechtips.com/topic/718017-sli-help/#findComment-9146643
Depends on the games that you play.....
https://linustechtips.com/topic/718017-sli-help/#findComment-9146646
You can get a new 480 which performs better for that much (assuming USD).
Med settings really should be easy enough on most mid-tier cards nowadays.
USEFUL LINKS:
https://linustechtips.com/topic/718017-sli-help/#findComment-9146656
Yes, but if you really like GTA or Overwatch, the GTX 1060 which costs just as much performs much better.....
https://linustechtips.com/topic/718017-sli-help/#findComment-9146663
