Audio Noise from monitors
R2ria
Good day comrades.
I am experiencing a very nasty issue.
I have Combo of 2 studio monitors (Presonus Eris E8) and subwofer (Presonus Temblor t10)
So it is playing just fine when i play it from Phone, TV other peoples laptop, even Bluetooth dongle.
But i get crazy amount of noise of all kinds when i connect it to my pc thru 3.5 jack on motherboard SABERTOOTH 990FX R2.0 am3+
Upgraded drivers, tried different types of wires between them and on the intake and wires all fine. Plugs and sockets were tested in different rooms and the result is always one.
PC works very fine with other speakers, headphones, microphone. No noise or anything that would unsatisfie.
I have Noise even when i connect PC to TV thru HDMI and then TV to Monitors. AS long as PC is in chain with speakers i always get noise, and it reacts to mouse movement.
NOISE STARTS ONLY WHEN WINDOWS ASKS FOR PASSWORD(Before that it is silent)
Let me know if you have any ideas what it might be, and maybe which part of hardware is causing that.
It sounds to me like something on the motherboard is interfering with the audio circuitry. You could try to use an add-in sound card, to see if that helps.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
I don't have one. And none of my friends do.
No amp, no equalizer, no external sound card.
If none will suggest anything that doesn't involve me to spend money on hardware i don't really need. I will get in few next days and post result.
if you have it plugged into the back 3.5mm port try the front one. i have the same problem and the one on the mobo gives a buzzing noise, but the port on the case doesn't
~i5-7600k @5GHz ~Be Quiet! Dark rock 3 ~MSI GTX 1070 Gaming X 8G ~Gigabyte GA-Z270-gaming K3 ~Corsair Vengeance Red led ~NZXT S340 Elite
  • 3 weeks later...
Was away on Holidays. Had to buy other front panel scince the old ones audio never worked from the day i bought the case.
And it still gives me the same sound. What next?> USB audio card? SO sad i have to get myself another device i dont really need and no guarantees that it will change anything.
OK, Same with USB SOUND CARD. I Will not even bother to put PCI EXpress sound card scince i am convinced that noise is coming from the case.
Please recomend maybe there is anything to do with BIOS? So i think i have only one option of bringing something like amplifier in chain to see if it will be the same(BUT HDMI to tv from this mobo was giving the same trouble when speaker were conected by aux jack in TV.)
CAN PSU cause anything like that?Water cooling?  I am really out of ideas...
