Help Picking 4k Monitor
Guest
Go to solution Solved by Pcinacan,
7 minutes ago, Emma Nieuwenhuis said:
they both look about the same just get the one that looks cooler to you
What gpu do you have?
CPUFX 8320, Motherboard ASUS M5A78L-M/USB3 Socket AM3+ AMD, RAM g.skill ripjaws x series (2x8gb), GPUstrix gtx 970, Storage 500gb + 500gb + 250 ssd, PSU EVGA 600w B 80 PLUS BRONZE, Display(s) ASUS VG248QE 24"+ Hisense 24" + Vizio 24", Cooling Cooler Master Hyper 212 EVO, PC Part Picker  http://pcpartpicker.com/p/LFxQ23
you could get a cheep 4k gamming monitor in Korea for about 600 USD, or another one made in the U.S witch I'm going to go find for you.
I have a GTX645. I am getting a 1070.
Just now, Noah Vega said:
I'm going to go find you the "best" inexpensive 4k displays :D
Well thank you, but that is not what I asked for.
Okay, thanks for your reply.
you miss understood, I'm going to find a monitor ith the same or better specs for a cheaper price.
misunderstood* and no I did not. I asked for help picking between these two monitors. I did not ask for other recommendations.
