DT 770 Pro 32 Ohms
Solved by applesuxD,
Just now, Dec_Shaw said:I hear people saying bose is a good make, but I'm not too sure.....
Bose is mostly popular for its wireless headphones which have very awesome active noise cancelling, best on plane flights, but if you dont use the noise cancelling, then other headphones at the same price point may sound better..
I would suggest you open another thread, asking about what type of headphones you want, and specifically stating for what uses.
