Does operating system stay on storage?
Go to solution Solved by Mira Yurizaki,
Short answer: yes, you can run the OS from the HDD after taking it offline.
Long answer: no, the current state will not stay. You have to update everything if you did so.
What i meant is like when i swap a HDD on a laptop with a new ssd, install os on the new ssd. Then maybe in future if i take out the ssd, and put back the original HDD (in the circumstances that i have not touch any of the data inside of it s8nce taking it out). Will the pc retain its previous form upon turning on?
https://linustechtips.com/topic/712713-does-operating-system-stay-on-storage/
Edited by M.Yurizaki
It'll retain the original settings present on the hard drive.
But Both your answer have the same length, haha. But thanks i got the answer.
11 minutes ago, SCHISCHKA said:
it will create a paradox and possibly tear a hole in the space-time fabric. proceed at your own risk
Troll much my friend
mark the answer as solved.
Judge a product on its own merits AND the company that made it.
How to setup MSI Afterburner OSD | How to make your AMD Radeon GPU more efficient with Radeon Chill | (Probably) Why LMG Merch shipping to the EU is expensive
Oneplus 6 (Early 2023 to present) | HP Envy 15" x360 R7 5700U (Mid 2021 to present) | Steam Deck (Late 2022 to present)
Mid 2023 AlTech Desktop Refresh - AMD R7 5800X (Mid 2023), XFX Radeon RX 6700XT MBA (Mid 2021), MSI X370 Gaming Pro Carbon (Early 2018), 32GB DDR4-3200 (16GB x2) (Mid 2022
Noctua NH-D15 (Early 2021), Corsair MP510 1.92TB NVMe SSD (Mid 2020), beQuiet Pure Wings 2 140mm x2 & 120mm x1 (Mid 2023),
