Top front side on an Monitor is Too Hot - Is this Normal ?
Solved by samcool55,
Monitors can get hot yes, but it should be fine.
I mean some people use notebooks while the sun is shining on the back of the monitor, causing it to get very hot.
But i've never saw one die because of it.
The worse case i saw of a monitor is that the film in front of the monitor got "burned" and turned slightly brown because it had a lamp right next to it that was pointed to the monitor.
It still works tho, it happened over a year ago and it's still working fine today.
So as long as it doesn't start to look burned or pixels stop working (turning black) it's fine, probably
