 Am still having trouble figuring out what to do here I finding answers to two different things with people in amazon saying that the bottom is the one I want and the newest version.
http://m.imgur.com/lrIxhIv  these are apparently both the lg "wh16ns40"  BOTH of them are I don't know if one if just an earlier model but I am not sure which one to look for because there are apparently like 2-3 different versions with different faceplates on them
Before anyone says it too the bh16ns40 also looks like both as well not just the bottom one
https://linustechtips.com/topic/710492-optical-drive/
Bottom one says BD rewriter so I assume that is the difference on is a reader only.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/710492-optical-drive/#findComment-9070544
5 minutes ago, AlwaysFSX said:
Have you tried checking the sticker on the drivel for model # and serial #?
This is what I mean if you look at both of these links
https://m.newegg.com/Product/index?itemnumber=N82E16827136269
https://m.newegg.com/Product/index?itemnumber=9SIA2W02TM3140
https://linustechtips.com/topic/710492-optical-drive/#findComment-9070549
But they are both listed as the same thing theybread and burn blh ray discs and same goes for DVD/CD
If you look at them them both there faceplate are completely different
https://linustechtips.com/topic/710492-optical-drive/#findComment-9070553
2 minutes ago, Dogsparky said:
Looks like they're in the same product family but different products.
https://linustechtips.com/topic/710492-optical-drive/#findComment-9070556
Then where do people on amazon buy the regular looking faceplate and get the other one lg is so confusing with this that they have to have two products with the same name
https://linustechtips.com/topic/710492-optical-drive/#findComment-9070562
2 minutes ago, NumLock21 said:
The bottom one is the older model, but it has a more premium face plate compare to the newer one. The LG logo is 3D and metallic and the eject button is part of the face place so it blends in. I have the bottom one on my ITX build.
So it will be harder to find the older one then? So which one is the one to get if I have windows 10?
https://linustechtips.com/topic/710492-optical-drive/#findComment-9070570
..why does the faceplate matter so much?
https://linustechtips.com/topic/710492-optical-drive/#findComment-9070583
Optical drive is optical drive don't matter which one you get. They all work with Windows 10. The only difference is the speed it can support when burning to disc. My only tops out at 14x, but I got that back in 2013.  The older face plate seems to be a new model also at 16x.
https://linustechtips.com/topic/710492-optical-drive/#findComment-9070586
1 minute ago, Dogsparky said:
Its not the faceplate/looks its that there is clearly something weird here and nktnsure which one to look for
What is weird about two drives with different face plates. If they're the same drive but different face plates that doesn't change anything about the drive.
https://linustechtips.com/topic/710492-optical-drive/#findComment-9070595
But you said yours is the older faceplate....I'm confused with lg
https://linustechtips.com/topic/710492-optical-drive/#findComment-9070598
But why dontheybhave a different faceplate ifntbey are the same drive
https://linustechtips.com/topic/710492-optical-drive/#findComment-9070606
The bottom is the older face plate because it's the same as my model which I got back in 2013. LG seems to have to use the older face plate on their newer model as well. Want a premium look on the drive get the one with the bottom face plate. Want a cheap feel, then get the top.
https://linustechtips.com/topic/710492-optical-drive/#findComment-9070612
Because products get refreshed over time to keep them looking new, they might have a minute difference in hardware design so the look may be changed. What does that matter?
https://linustechtips.com/topic/710492-optical-drive/#findComment-9070614
So they are the same drive with different faceplate? So you have the older 14x version and the newer 16x is what you are saying as a older face place on the newer model,and then the newest version they got is the ordinary one,ok now that makes a bit more dense
https://linustechtips.com/topic/710492-optical-drive/#findComment-9070634
Newest Blu-Ray writer right now is at 16x
LG seems to have use the older face plate for the newer models
LG also seem to have made another face plate for these newer models
Old face plate has a 3D LG logo on the disc eject tray
New face plate has a LG logo that's printed on
Don't matter which on you get, as long at it's 16x, but the older face plate makes it look a lot nicer.
Old face plate, notice the LG logo and eject button
New face plate, notice its logo and eject button
lg_electronics_wh16ns40_16x_internal_bdx
https://linustechtips.com/topic/710492-optical-drive/#findComment-9070674
Ok thank you so it I guess I will just go buy regular looking one then
https://linustechtips.com/topic/710492-optical-drive/#findComment-9070701
