Everything looks fine on that new link now.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/709509-thoughts-on-build/#findComment-9059182
7 minutes ago, KeFy said:
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($332.99 @ Amazon)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  ($34.88 @ OutletPC)
Motherboard: MSI Z170A KRAIT GAMING 3X ATX LGA1151 Motherboard  ($118.48 @ B&H)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR4-2133 Memory  ($99.99 @ Newegg)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory  ($74.99 @ Newegg)
Storage: PNY CS1311 240GB 2.5" Solid State Drive  ($64.99 @ Jet)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.78 @ OutletPC)
Video Card: MSI GeForce GTX 1080 8GB Video Card  ($608.54 @ Amazon)
Case: NZXT S340 (White) ATX Mid Tower Case  ($90.39 @ Amazon)
Power Supply: EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($84.99 @ NCIX US)
Monitor: Acer CB280HK bmjdppr 28.0" 3840x2160 60Hz Monitor  ($299.99 @ Newegg Marketplace)
Total: $1860.01
Generated by PCPartPicker 2016-12-20 08:18 EST-0500
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/709509-thoughts-on-build/#findComment-9059197
Memory: G.Skill Ripjaws 4 Series 16GB (2 x 8GB) DDR4-3000 Memory  ($84.97 @ Jet)
Video Card: EVGA GeForce GTX 1080 8GB ACX 3.0 Video Card  ($619.99 @ NCIX US)
Power Supply: Rosewill 750W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($89.99 @ Newegg)
Monitor: AOC U2879VF 28.0" 3840x2160 60Hz Monitor  ($289.99 @ Newegg)
Total: $1776.45
Generated by PCPartPicker 2016-12-20 08:24 EST-0500
https://linustechtips.com/topic/709509-thoughts-on-build/#findComment-9059215
