I need a good 16x pci-e cable
NaorG
I need 16x pcie cable for my graphics card.
I want flip my gpu from horezantel(-) state to vertical(l) state, so i will see it through the glass case.
So i have 2 question and 3 requirements:
  • Questions
  1. Will i have a battelnack?
  2.  Dos it have a down side?
  • Requirements
  1. Needs to be small.
  2. The highest quality posible.
  3. Strong and long lasting.
BTW:im using ROG STRIX-GTX1070-O8G-GAMING.
It will definitely lower your performance, although just marginally.
bearly if even really , we are talking margin of error numbers here (1~2fps)
@NaorG
look on ebay for "pcie riser" and you will find what you need
RyzenAir : AMD R5 3600 | AsRock AB350M Pro4 | 32gb Aegis DDR4 3000 | GTX 1070 FE | Fractal Design Node 804
RyzenITX : Ryzen 7 1700 | GA-AB350N-Gaming WIFI | 16gb DDR4 2666 | GTX 1060 | Cougar QBX
PSU Tier list
as long as the pcie riser is rated for pcie 3 x16 you shouldn't have a problem, there shouldn't even be a measurable performance hit as long as everything connects and functions properly.
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
Ware will i  see/feel the difference
In what form factors?
Fps, overall speeds, rendering Etc?
@NaorG
You said the same exact thing as me, just with different words, why?
Overall performance, it trickles down into everything the GPU is used.
¯\_(ツ)_/¯
PSU Tier list
Just now, Space Reptile said:
¯\_(ツ)_/¯
Okay :D
Though your's sounds friendlier, as I left the positive to the very end (marginal).
@NaorG
It was very helpfull, ty.
I need a brand name and madul
because i dont trust selets on the internet.
Btw: how did you tag me?
12 minutes ago, NaorG said:
Btw: how dos you tag me?
type an "@" and then the name , it shud give you a selection
I honestly cant tell you if there even is a brand name cable for that , and honestly , they are all the same
also they are so cheap , buy 2 or 3 and if one is dead its not a huge loss
PSU Tier list
