Either clean your drive of unneeded material, or buy this: https://www.amazon.com/Blue-Cache-Desktop-Drive-WD10EZEX/dp/B0088PUEPK
Motivation is where, and what you make of it.
“It is relatively unusual that a physical scientist is truly an atheist. Why is this true? Some point to the anthropic constraints, the remarkable fine tuning of the universe. For example, Freeman Dyson, a Princeton faculty member, has said, ‘Nature has been kinder to us that we had any right to expect.'”  Albert Einstein
https://linustechtips.com/topic/705685-help-please/#findComment-9015881
4 minutes ago, niff said:
but then what happens to all my stuff on my hardrive
Do you have any other SATA connectors on your board?
https://linustechtips.com/topic/705685-help-please/#findComment-9015893
Hi,
Windows 10 has brain failure with alot of process's.
Our Virus Protection at work uses 100% disk usage for ages when we first turn them on everyday.
Is there any program listed as using the majority of the disk in task manager ? (Such as below )
muo-windows-w10-hdd100-taskmgr
Hayabusa
https://linustechtips.com/topic/705685-help-please/#findComment-9015989
1 hour ago, niff said:
please help
1) Defragment your hard drive.
2) Identify what program is reading/writing to the hdd and see if there is a wayto stop it.
3) Get a ssd to use as a boot drive, it will help with OS functioning faster, but the hdd will probabbly still hit 100% when you use it, but just not as much since the OS is the biggest program that uses the disk.
If anybody tells you formatting the hdd will help, don't, it wipes the drive for no gain at all in speed, in windows refreshing the OS does the same without losing your data.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/705685-help-please/#findComment-9016211
I think the "100% Usage" you are seeing is something ridiculous like % of time disk accessed? Your OS may be accessing the disk 100% of the time, but may only use ,in Hayabusa1989's case, a total of like 4Mb/s.
To see for yourself, check the resource monitor or detailed performance view. And don't hate me if I'm wrong. lol
I work on many laptop computers with windows 10 on them. This raised my concern when every laptop I handle would show "100% disk usage".
If you pull up the resource monitor, or detailed performance view, you will see more then one metric for disk measurements.
If I recall correctly these new numbers show what was actually at 100%. and if i recall it was the time the disk is being accessed. So even simple OS tasks, for the time it is doing so, the disk would have been at 100. close to those numbers i remember seeing 20% actual disk usage, despite the task manager labeling that "100%" as disk usage.
Pretty obnoxious if you ask me.. Hope this helps...
Love to all the LTT team and community
https://linustechtips.com/topic/705685-help-please/#findComment-9016880
I confirmed from my post earlier.
Click on the performance tab if the task manager
Click on the Disk graph to the left.
Now you should see Disk Access time, and Disk Transfer Rate.
The Access time always spikes to 100, while transfer rate never really does.
This is what is giving you the false sense that your disk is either dying, or peaking out at 5Mb/s.
That 100% measurement us simply the time the disk is being accessed. Which is funny because it either is or it is not....
0 to 100 real quick *pun*
https://linustechtips.com/topic/705685-help-please/#findComment-9028129
