How to connect hard drive?
3 minutes ago, xmodex said:Building pc for first time ; d
How do i connect hard drive daym it has 3 connectors (i think)
I have toshiba 3tb and this is the only image i could find
Idk if you can see clearly but i think those are 3 connectors, anyone know this how to connect it properly? as theres no instruction on it lmao maybe im just newbie
you just need to know sata power, and sata data.
Sata is the name of the plug. Just as your computer has a USB plug, and your phone has a micro or mini USB, or lightning connector, it's just the name.
Your power supply SHOULD (may not depending how old it is) have a sata power connector. It will be shaped like an "L"
Your motherboard MAY come with a Sata data cable. It's smaller than the power cable. You plug one end into the HDD and the other into any one (It doesn't matter) connector on your motherboard that says SATA. If the motherboard is even relatively new it should be fine. If it's older it's a different type of sata but we're talking pretty old stuff.
my 2009 Motherboard has the right sata so you shouldn't have to worry.
I think that's all I can say. Youtube videos are a great way to learn how to build a PC. Search things like "How to install a hard drive to a computer" or "How to build a PC"
I like watching Newegg's channel on how to build PCs. I believe linus or techquickie has a video or 2 on actually building PCs, and more in general stuff, like what tools to get.
