Should I bother with a different CPU cooler
Solved by Simon771,
I had that same CPU, and I can tell you that you don't need any other cooler.
56°C is cold for CPU.
If it would get up to 80°C I would concider doing something about it.
But as long as your temps are under 70°C you are just fine.
It's not worth to get any other cooler for that CPU. There won't be any benefit from it. Thermal throttling will become active when you reach 95°C, so you are faaar away from that.
Featured Topics
3
LucasTSP ·
Posted in General Discussion2 -
madsci1016 ·
Posted in General Discussion0 -
Jimmie22 ·
Posted in Troubleshooting9 -
SnowYetti ·
Posted in Cases and Mods1 -
4
2
6
