I don't know what card to pick. My build is here (https://pcpartpicker.com/list/sVtMTH) and I would rather only pay about 150-170 for the GPU, its a budget build, I want to be able to run Just Cause 3 medium settings 1080p 60 fps, in addition to other triple a titles. Also what do you think of the build?
https://linustechtips.com/topic/697749-help-picking-card/
RX 470.
https://linustechtips.com/topic/697749-help-picking-card/#findComment-8928934
RX470
Or if you're comfortable buying used you can probably get a 980 or 390 or something like that.
https://linustechtips.com/topic/697749-help-picking-card/#findComment-8928937
RX 470 hands down
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
https://linustechtips.com/topic/697749-help-picking-card/#findComment-8928946
1 minute ago, fpo said:
RX 480s should be in that range. Otherwise 1060s are about 250 USD. If not 1050s are pretty low priced.
Did you see his price range? RX 470 is the best option for around $170
https://linustechtips.com/topic/697749-help-picking-card/#findComment-8928955
Which rx 470? Stock? Msi? Asus? Oc edition? Overpriced edition? TOO MANY CHOICES!!?!?!?!?!
I'd recommend an MSI version. Generally they're all the same. OC means overclocked.
This one for instance isn't bad. I'm not sure the memory configurations that are available for the 470 though.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814137050&cm_re=RX_470-_-14-137-050-_-Product
https://linustechtips.com/topic/697749-help-picking-card/#findComment-8928957
4GB is an option lol
https://linustechtips.com/topic/697749-help-picking-card/#findComment-8928967
4 minutes ago, Enderman said:
RX470
Msi armor version?
Yeah, I was gonna go with a higher up 1060 but I didn't realise it was on sale and it wasn't the base price lol.
Looks good!
MSI Radeon RX 470 4GB ARMOR OC Video Card
Is this good?
https://linustechtips.com/topic/697749-help-picking-card/#findComment-8928968
The only answer to that question is yes
https://linustechtips.com/topic/697749-help-picking-card/#findComment-8928971
I'd recommend this:
http://www.newegg.com/Product/ComboBundleDetails.aspx?ItemList=Combo.3121721
But it's literall 100 USD under your budget.
Opinions on saphire? I have NO experience with this brand.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202226&cm_re=RX_470-_-14-202-226-_-Product
It's 214 USD but it's 8gb.
https://linustechtips.com/topic/697749-help-picking-card/#findComment-8928983
5 minutes ago, fpo said:
I'd recommend this:
Well I think the 4gb should be good enough for what I need it for. But if you think its not good please say?
https://pcpartpicker.com/list/VT4xbj
https://linustechtips.com/topic/697749-help-picking-card/#findComment-8929023
I'd throw out the cooler on your build, as the stock cooler on the i3-6100 is more than enough so no reason to spend any money on an aftermarket one. Otherwise it's pretty efficient for performance per dollar.
https://linustechtips.com/topic/697749-help-picking-card/#findComment-8929183
Sounds good. You know of any CPUs that are better for only like 30 USD more?
https://pcpartpicker.com/list/gYHdr7
https://linustechtips.com/topic/697749-help-picking-card/#findComment-8929190
The i3-6300 is a very very minor upgrade at $140 since it runs 100MHz faster and has 1MB more L3 cache than the i3-6100. I don't think it's worth it myself, save that extra $35 for the steam sale. The cheapest CPU that would be a significant upgrade would be the $175 i5-6400 (though the $190 i5-6500 is a better deal). I wouldn't pull money out of your gpu budget though to upgrade the cpu, as the RX 470 is one of the best gpus for the money I have seen in years.
https://linustechtips.com/topic/697749-help-picking-card/#findComment-8929234
The i3-6300 is a very very minor upgrade at $140 since it runs 100MHz faster and has 1MB more L3 cache. I don't think it's worth it myself, save that extra $35 for the steam sale. The cheapest CPU that would be a significant upgrade would be the $175 i5-6400 (though the $190 i5-6500 is a better deal).
Hmmm allright thanks for the input
https://linustechtips.com/topic/697749-help-picking-card/#findComment-8929242
