Hello forum, I have a 30 Mbps internet connection and a AC750 Wi-Fi router.
The only device on my home network with an AC network card is my cell phone.
The Maximum actual download speed that I see on the phone is 7 MB per second. Now, my question is .....is my Wi-Fi router limiting the download speed here ? If  I were to connect a AC1750 router, will it improve the download speed to 17 MB per second?
Please let me know.
Thanks!!
https://linustechtips.com/topic/695719-does-ac-router-increase-speed/
AC1750 usually just means there are 2 or more WiFi bands, and their sum is 170 mbps. You won't really see a difference
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
Usually not, actual download and upload speeds are mostly from your ISP. Pay more for faster up/down speeds etc. If you are using your ISP's modem or cable modem you could always request for updated equipment.
Thanks!
Chris R.
most smartphones have a 1x1:1 wifi antenna design, since your wifi router is classified as ac750, it also, most likely, has a 1x1:1 design for the 5ghz band.
if your phone is the only client on the 5ghz band, an ac1750 router won't increase throughput.
if you have more than 1 simultaneous client on the 5ghz band you might feel an improvement since an ac1750 rated router likely has a 3x3:3 mimo design, which supports more spacial streams, and can thus support more clients better.
in any case, i think it's amazing you can download at 7MBps (56Mbps) on a 30Mbps connection...
Actually most smartphones are sporting 2x2 MIMO or MU-MIMO antennas nowadays. Samsung has had 2x2 MU-MIMO from the S5 to current s7 models.Microsoft, Google OPPO, ZTE and LG also have it on their phones to name a few.  (Some phones even sport 4x4 MU-MIMO antennas.) Not sure about spatial streams but assuming 2 that would mean 2x2x2. Ac1750 should be able, assuming MCS-9 (modulation and coding scheme 9= 256QAM and 5/6 coding rate, with channels 40,80 or 160MHz wide and a 800 or 400ns guard interval) and 2 spatial streams (possible with MU-MIMO 2x2) to provide between 360 and 1733 Mbps. (Halve those numbers for one spatial stream at MCS-9)
Now that won't speed up your WAN connection....so 30Mbps or about 3.4MB per second should be your speed limit when downloading from the internet.
This does not take into account any interference due to neighbors lousy old 802.11a wifi router, interference due to radar or non-802.11 5GHz devices or other wifi channel congestion or interference or physical interference (walls, stucco, concrete, trees etc)  and the throughput is the theoretical maximum.
Suffice to say it's unlikely your wifi will be the bottleneck in your network. More likely your internet connection will be your bottleneck.
