wii u will my monitor work
KeFy
will my benq gl2450 work with the wii u
it does NOT have a hdmi port only dvi will an adapther from hdmi to dvi work ?
Yes. Personly, I find that grammar and punctuation makes a sentence not only mean more, but makes it understand it. I can understand if you speak another language, but there is no excuse for not hitting the shift button.
Adapters are built for the scenario you are describing, so, it will work just fine. As long as you can plug it in.
However, not that it will matter to you, things do get more complicated when dealing with multiple displays.
Computers r fun
