Need some opinions on my first build
Personally, I think that you don't really need the air cooler at $49, could spend a little more and go AIO water, or less and get fine performance with something a little simpler like a Cooler Master 212 EVO or similar.
I would say that when/if you ever desire to upgrade your CPU to a K series part for overclocking, you will find that you want an AIO water solution anyway. But since the AIO solution won't provide much benefit if any in terms of your experience using the standard clocked i5, I would save the money now and go with the 212 Evo or similar. Put that money into an SSD, and you won't feel so bad about ditching the $50 air cooler later when you want to upgrade.
I myself started with a CM 212 EVO, but seeing as I had a K series i5 that was hot as hell, I upgraded to a h100i from Corsair for overclocking. Ultimately proved futile, as my little chip is just about worthless for overclocking. Many hours of tweaking, low voltages, high voltages, aiming at modest clockspeed boosts and still no stability. Eventually decided to just run it stock, keep the AIO cooler for an upgrade.
If you are only interested in the specified cooler for aesthetic reasons, then I suppose this argument won't sway you much, but the clean metal finish and black fans common to most tower air coolers wouldn't likely be an eyesore. Especially if it is only temporary pending an upgrade as discussed.
Long story short that's my two cents, good luck on the build, and an overall nice job picking parts for your budget. Shame that you'll have to buy an OS, but that's the way the cookie crumbles.
