So i was unaware that only Z-170 chipset supports Overclocking for SKYLAKE Processors. And i went ahead purchased Core i5-6600K & ASUS B-150M Plus Motherboard. I'm unable to overclock the CPU and replacing the motherboard is not an option. Is there anyway to overclock the i5-6600K on a B-150 Chipset Motherboard..... Please Help :(
https://linustechtips.com/topic/692230-overclocking-on-b150-need-help/
No, if you can't overclock, you can't overclock.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
No.
8 minutes ago, Thread212 said:
I never own B150 mobo but i think u can if u are savy enough.
But i am not sure if u can overclock on B150 mobo. and why do u want to overclock it anyway?
is 3.90 Ghz not enough for your game?
3.9 GHz maybe enough for now... but what about future.... also i spent $80 on cooling accessories just because of i5-6600K.
It's enough in the future. Less has been enough for a long time. It's a 4-core. You're fine. But once you can afford it, just buy a new motherboard. Maybe wait for the 200-series chips.
Just now, Thread212 said:
Then u are doing a mistake if u want to be more futureproofed by buying 6600k..U could buy 6700k or buy a cheap pentium G series and wait for kaby lake if u are a man of patience.
Although 6600k is enough for maxed out AAA games for now or at least 2 years later.. who knows.
i don't know if you follow linus or no.. but buying a 6700k would have been an overkill for me.... all i wanted to do is pure gaming.
the retailer wont take it back, and z-170 motherboards start at $130 in my area.
So that's the reason. Not sure how much this B150 cost for you, but
6600K with Hyper 212 Evo is good enough and that should leave you with money to spare on a  Z170 board.
Lesson learned here. Only Z chipset from Intel officially supports overclocking.
my budget was $1100
Corsair Spec-100R w/ One Fan- $56
Hyper 212X - $41
2x140 NZXT Fans - $24
2x120 NZXT Fans - $15
------------------ OR ------------------
Corsair H45 Liquid Cooler - $66
What would you prefer ?
44 minutes ago, m3D!c said:
my budget was $1100
Hyper 212X - $41
First one right off the bat. And  I won't not even grab the extra fans. Core component first, everything else come second.
