Hi LTT
At the moment i am running my internet via a 4g/lte connection on the router my ISP provided me with.
If i am lucky i can get a 18/1 connection, but i am not entirely satisfied with it.
I live in a flat on the lowest floor and i have the router by the window facing the center of my city, so i should have given the router the best chance of getting a good connection.
Would i be able to improve my connection my spending money on a higher quality 4g/lte router or would the difference be negligible?
I have checked the possibilities of getting a wired connection, but the copper wires going to my appartment can give me 12/1 mbit.
I hope some of you have good knowledge of this and can share it with me (And others in need)
https://linustechtips.com/topic/692132-improving-connection-with-4g-router/
The difference would most likely be negligible since it's more the tower itself which will give you the connection speed than the receiving router. So unless you can get a tower closer to your location there isn't much that will help.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
With LTE there are tons of factors. Firstly there are the speeds the tower can handle. I live in the City of Romulus I get 20Mbps down on T Mobile on my phone. Go to Canton, I can get 90Mbps down. There also is how congested is the tower, how far away. How many bars is the router getting from the tower (Signal Strength). I personally would settle for the 12/1 connection as Im sure the latency would be lower than LTE and it might be more reliable in the long term.
