I would like to know if anyone has ever tried cutting out small magnetic pads and gluing them to the areas threaded for the case fan screws and then mounting the fans to their case. I was thinking about trying it but I have a small quantity of cheap fans to sacrifice for the project or the time to be willing to try a mod like this. In theory, this will make cleaning case fans a lot easier without having to deal with screws to remove them.
If anyone has ever tried it, I'd like to know what your results were.
Desert Storm PC | Corsair 600T | ASUS Sabertooth 990FX AM3+ | AMD FX-8350 | MSI 7950 TFIII | 16GB Corsair Vengeance 1600 | Seasonic X650W I Samsung 840 series 500GB SSD
Mobile Devices I ASUS Zenbook UX31E I Nexus 7 (2013) I Nexus 5 32GB (red)
https://linustechtips.com/topic/69040-fan-modding/
This is not a bad idea, though I imagine it will cause issues with fans that are mounted between a hard drive cage and the front of a case.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/69040-fan-modding/#findComment-946606
possibly they wont hold on because of the vibrations caused by the fans themselfs... they will rattle down slowly
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
https://linustechtips.com/topic/69040-fan-modding/#findComment-946640
https://linustechtips.com/topic/69040-fan-modding/#findComment-946658
I was referring to the magnet theory he pointed out...
tape... uhmm...
https://linustechtips.com/topic/69040-fan-modding/#findComment-946665
tape... uhmm...
I was saying that tape is the solution to the possible vibration issues, tape fixes everything.
https://linustechtips.com/topic/69040-fan-modding/#findComment-946669
No there would be no problems with the HDD unless you have a SUPER powerful magnet that can mess with the linear actuator.
Mein Führer... I CAN WALK !!
https://linustechtips.com/topic/69040-fan-modding/#findComment-946671
I was referring to the space between the fan and the HDD cage, in my case the drive cage is flush with the front fans, adding a pair of magnets would make it where the drive cage couldn't be mounted.
https://linustechtips.com/topic/69040-fan-modding/#findComment-946673
Oh ok I see what your saying.
https://linustechtips.com/topic/69040-fan-modding/#findComment-946674
Anybody willing to try this? I wish I could diagram what I'm trying to say to clarify my point a bit further.
https://linustechtips.com/topic/69040-fan-modding/#findComment-946682
You would have to hot glue some lager neodymium magnets to the fan.
I'll be sure to look into that.
https://linustechtips.com/topic/69040-fan-modding/#findComment-946759
