Just now, rphawks said:
Do you have Makerbot Desktop? You can convert from STL to .makerbot in that. I don't want to download it for a one time use, so yknow.
OK. do it in .sti and I can do it
Breaking things 1 day at a time
13 hours ago, W-L said:
What is this for now, if your 3D printing it with that much overhang it will not be very strong espically if it's very thin material like in the DVD slot.
I could do scaffolding and sand it out to help
Yes but it's still a thin cross section that will be inserted partially into the drive my worry would be keeping tolerances when making the part and not having it break off inside. Why not just get an aluminum muse pad and use it on the side or overlay onto of the laptop.
We'll print vertically. No overhang/scaffolding required.
Skyggeis Specs:
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor
CPU Cooler: CRYORIG H5 Ultimate 76.0 CFM CPU Cooler
Motherboard: MSI Z170A SLI PLUS ATX LGA1151 Motherboard
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000
Storage: Samsung 850 EVO 250GB 2.5" Solid State Drive
Storage: Western Digital Caviar Blue 1TB 3.5" Hard Drive
Video Card: Zotac GeForce GTX 1070 8GB AMP! Extreme
Case: Phanteks ECLIPSE P400S ATX Mid Tower Case Satin Black
PSU: Corsair RMx 750W 80+ Gold Certified Fully-Modular PSU
WiFi Card: Gigabyte GC-WB867D-I REV 4.2
Case Fan: Aerocool DS 140mm Black 93.4 CFM
Other: Coolermaster VGA Holder
Other: Phanteks LED Strip 1M
Other: Phanteks Fan Splitter
Monitor: Dell S2716DG
Yes that's doable but the fact that it is still a thin cross section being canter-levered is what I'm concerned about mainly since it won't be very strong in resisting moment or bending.
That is true. We could make the middle part shorter.
Skyggeis Specs:
I was thinking if you got an aluminum mouse mat and found a good way of modularly attaching it that would work well but I'm having trouble thinking of a good method for it to just clip in place easily and quickly.
Give this print a try. Made length 12 instead of 12.3 because of Apple's CD slot with the curved sides. If it doesn't fit, I'll reduce the dimensions. DO NOT print with overhang. Either vertical or on it's side.
v1.stl
Skyggeis Specs:
v1.stl
OK thanks
