Can someone help me 3D model a mousepad thing for my macbook pro? Im not great at 3D modeling so im on here. Sorry for my shit MS paint idea.
So basically it part of it would sit in the CD/DVD slot, and then on top and on bottom of the macbook. (The black would be the 3D printed Thing)
And then this is a garbage x-ray style of what it would look like
It would be for a 2012 MacBook Pro 13", basically giving it a 17" footprint. Please let me know if you can do anything. It would be very useful
Breaking things 1 day at a time
https://linustechtips.com/topic/690374-help-3d-modeling-a-thing/
Hm... are you sure this would work well? Unless you have a liquid printer, the top surface would turn out with little grooves.
Skyggeis Specs:
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor
CPU Cooler: CRYORIG H5 Ultimate 76.0 CFM CPU Cooler
Motherboard: MSI Z170A SLI PLUS ATX LGA1151 Motherboard
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000
Storage: Samsung 850 EVO 250GB 2.5" Solid State Drive
Storage: Western Digital Caviar Blue 1TB 3.5" Hard Drive
Video Card: Zotac GeForce GTX 1070 8GB AMP! Extreme
Case: Phanteks ECLIPSE P400S ATX Mid Tower Case Satin Black
PSU: Corsair RMx 750W 80+ Gold Certified Fully-Modular PSU
WiFi Card: Gigabyte GC-WB867D-I REV 4.2
Case Fan: Aerocool DS 140mm Black 93.4 CFM
Other: Coolermaster VGA Holder
Other: Phanteks LED Strip 1M
Other: Phanteks Fan Splitter
Monitor: Dell S2716DG
https://linustechtips.com/topic/690374-help-3d-modeling-a-thing/#findComment-8856266
Sandpaper? Also there will be a mousepad on top of it
https://linustechtips.com/topic/690374-help-3d-modeling-a-thing/#findComment-8856303
Oh you're going to put a mousepad on top. Thought you would use it just for the mousepad. I could design something if you send me all the dimensions.
Skyggeis Specs:
https://linustechtips.com/topic/690374-help-3d-modeling-a-thing/#findComment-8856312
Yeah I can. Can you give me 3 hours? Im going to see a movie. (Also, metric or American)
https://linustechtips.com/topic/690374-help-3d-modeling-a-thing/#findComment-8856320
Ummm... Cm will do.
Skyggeis Specs:
https://linustechtips.com/topic/690374-help-3d-modeling-a-thing/#findComment-8856345
4 hours ago, rphawks said:
Ummm... Cm will do.
Ok.
Main Body:
1.5Cm thinck
22.5 wide
32.5Cm long
CD:
.4CM up-down
12.3 Cm across
8.5Cm from the front of the laptop
1.5Cm from the back
Center of the CD (Up-down) is 1Cm from the bottom
.65Cm from top to center of CD
Top of CD player is .5CM from top
Bottom is .7Cm from bottom of laptop
Extra things:
Top would extend onto the laptop 16.5 CM (From the left to where I would like it)
There would be 2 plastic pieces that extend all the way across the bottom (Lift up the laptop and give it some support)
Not sure if this helps, but
https://linustechtips.com/topic/690374-help-3d-modeling-a-thing/#findComment-8857573
What's the first part of the picture?
Skyggeis Specs:
https://linustechtips.com/topic/690374-help-3d-modeling-a-thing/#findComment-8857583
Just now, TubsAlwaysWins said:
If you give me 20 hours I can get you measurements for the 3D printer I am using
Ok. Something like this would have to be printed in one piece, going vertical.
Skyggeis Specs:
https://linustechtips.com/topic/690374-help-3d-modeling-a-thing/#findComment-8857596
Its a Makerbot Replicator 2
Oh perfect. It's the one I used to work with at school as well. The one with the little screen in the bottom left, right?
It only prints 11 in, so about 27 cm. That's a problem.
Skyggeis Specs:
https://linustechtips.com/topic/690374-help-3d-modeling-a-thing/#findComment-8857616
Yeah. Thats why I was wondering if it could be in 2 parts. Or if you could do 2 parts but with divits and I can superglue it together or something
https://linustechtips.com/topic/690374-help-3d-modeling-a-thing/#findComment-8857623
If you shrink the bottom part to 16.5 cm as well, it should be able to print in one run.
Skyggeis Specs:
https://linustechtips.com/topic/690374-help-3d-modeling-a-thing/#findComment-8857624
This is for use on your lap right? If so, I can just make the bottom part shorter but thicker so it has the same strength.
Skyggeis Specs:
https://linustechtips.com/topic/690374-help-3d-modeling-a-thing/#findComment-8857631
Tell you what. Since it is my schools 3D printer, and I have unlimited filament (#Gov't Funding) do we want to try different things? Another thing I was thinking was if you didn't do the main plastic piece so I can make sure it fits and I don't waste lots of filament and time. (The piece that extends the laptop) (Then add the plastic once I verify it fits)
https://linustechtips.com/topic/690374-help-3d-modeling-a-thing/#findComment-8857635
How about this. We do two runs.
1. Just the CD part. I remove the mouse part and shorten the top and bottom to sort of have a three-prong block thing. You make sure it fits.
2. Then I add the mouse part and make the top and bottom parts longer.
Skyggeis Specs:
https://linustechtips.com/topic/690374-help-3d-modeling-a-thing/#findComment-8857650
Yeah thats what I was trying to say
https://linustechtips.com/topic/690374-help-3d-modeling-a-thing/#findComment-8857652
Okay. I'll have it by tomorrow probably. I'm writing an essay right now. :/
Skyggeis Specs:
https://linustechtips.com/topic/690374-help-3d-modeling-a-thing/#findComment-8857662
Lol have fun. Thanks
Ideally I would like to have it finished by Wednesday but realistically that won't happen
https://linustechtips.com/topic/690374-help-3d-modeling-a-thing/#findComment-8857666
Oh also, I'm assuming you want it in .stl?
Skyggeis Specs:
https://linustechtips.com/topic/690374-help-3d-modeling-a-thing/#findComment-8857710
Whatever Makerbot prints in. (I think it is .makerbot)
Do you have Makerbot Desktop? You can convert from STL to .makerbot in that. I don't want to download it for a one time use, so yknow.
Skyggeis Specs:
https://linustechtips.com/topic/690374-help-3d-modeling-a-thing/#findComment-8857725
