Best graphics card for $200 USD
Eddyk
I am wondering what graphics card i should get, i was looking at the gtx 1060 3gb ddr5. This is the card i am looking at https://www.amazon.com/Gigabyte-GeForce-Windforce-Graphics-GV-N1060WF2OC-3GD/dp/B01KQUDE2Y/ref=sr_1_2?s=pc&ie=UTF8&qid=1479022886&sr=1-2&keywords=1060%2B3gb&th=1
Or i was going to spend the extra $20 for a red and black to match my PC  https://www.amazon.com/MSI-GAMING-GTX-1060-3G/dp/B01KIJ7XQG/ref=sr_1_4?s=pc&ie=UTF8&qid=1479023060&sr=1-4&keywords=1060%2B3gb&th=1
Thoughts on the 1060 or what card should i buy.
Welcome to the forum!
The 1060 is a great 1080p card. They're all good, though the MSI ones have proven to be a little better. I'd go with that, since it matches your build. I'm a sucker for proper aesthetics.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
same, my k70 my fan led, my whole room and build is red and black. i also heard some things about the rx480
I would say that you should go with the Red MSI gtx 1060, mainly because it would match your build, if you get or already have a case with a side panel it will just fit it better, also from the amazon link you sent for me it doesn't have a $50 price difference its around $20 - $30 so I would  go with that!
MochPot: AMD Ryzen 5 2600, 16GB 3200MHz DDR4, ASRock X370 Fatality K7, 8GB Nvidia GeForce GTX 1070, 256gb Salvaged Intel Rando NVME SSD, Corsair RM750x, Corsair Carbide 275R, Windows 10 Pro
ZenServerRequiem: AMD Ryzen 3 2200g, 32GB 3200MHz DDR4, MSI B450 Gaming Plus, 4GB Nvidia GeForce GTX 960, 2GB Nvidia Quadro P400, 500gb Salvaged Intel Rando NVME SSD (Cache Drive only), 3 x Seagate Baracuda 2TB, Corsair CX500, Corsair Carbine 750T, Limetech Unraid (Running Plex, Jackett, Sonarr, WireShark, Duck DNS, Ubuntu Server VM for MC server)
