So i turned on dx12 and at the start of a game it stutters but 3mins into the game it's buttery smooth and CPU  usage never goes above 65% and before it would reach 100%. If anyone know the fix for the stutters pls let me know.
Spec in my signature down below.
System
  • CPU
    I7 6700K Overclocked to 4.6 GHz at 1.33v
  • Motherboard
    Asus Z270 PRIME - A
  • RAM
    GSKILL RIPJAWS V DDR4 16GB 3000MHZ
  • GPU
    MSI GTX 1070 GAMING X 8G overclocked to 2063 MHZ and 8900 MHZ memory clock
  • Case
    NZXT S340 RED
  • Storage
    WD 1TB BLUE AND SAMSUNG EVO 250GB SSD
  • PSU
    EVGA 650W GQ
  • Display(s)
    LG 25UM58-P ULTRAWIDE and LG 29UM58-P 29 ULTRAWIDE
  • Cooling
    CORSAIR H100I GTX
  • Keyboard
    CORSAIR K70
  • Mouse
    LOGITECH G502 PROTEUS SPECTRUM
  • Operating System
    Windows 10 PRO
https://linustechtips.com/topic/689276-insane-bf1-cpu-usage-fix/
I don't get this Battlefield 1 CPU usage problem, it is just a sign of good optimization.
If you don't reach your desired frame rate target (e.g. 60fps on a 60hz monitor) then yes there are problems.
But if you play BF1 with an uncapped frame rate and have a good GPU it is going to render frames until it becomes bottlenecked, be it CPU or GPU. Usually whoever hits 100% usage first.
My 6600k doesn't come close to 100% CPU usage with vSync on.
https://linustechtips.com/topic/689276-insane-bf1-cpu-usage-fix/#findComment-8845201
He has an i7-6700K and a GTX 1070.
https://linustechtips.com/topic/689276-insane-bf1-cpu-usage-fix/#findComment-8845216
frostbyte3 engine doesnt render unlimated fps, it has a certain cap, and gtx 1070 doesnt pull enough frames to bottleneck a 6700k, so no its not a sign of good optimization.
https://linustechtips.com/topic/689276-insane-bf1-cpu-usage-fix/#findComment-8845219
i'm having a hard time trying to understand what OP is talking about.
Quote
https://linustechtips.com/topic/689276-insane-bf1-cpu-usage-fix/#findComment-8845253
What I'm trying to say is that I used to get 100% usage on my CPU but then I turned on dx12. It turned my CPU down to 50%, but when I join a conquest game, for the first 3 mins there is some stutters but then after 3 minutes the gameplay becomes very smooth. I wanted to know if anyone had a fix for the stutters at the beggining of the game.
System
  • CPU
  • Motherboard
    Asus Z270 PRIME - A
  • RAM
  • GPU
  • Case
    NZXT S340 RED
  • Storage
  • PSU
    EVGA 650W GQ
  • Display(s)
  • Cooling
    CORSAIR H100I GTX
  • Keyboard
    CORSAIR K70
  • Mouse
  • Operating System
    Windows 10 PRO
https://linustechtips.com/topic/689276-insane-bf1-cpu-usage-fix/#findComment-8845383
First 3 minutes it stutters, after that it runs smooth. Is that even a actual problem or what you thought it is a problem?
I play R6V during my free time, when I had a Nvidia GPU the unreal logo was smooth, after upgrading to a AMD GPU, the unreal logo stutters, then everything runs smooth. Maybe I should do a find a fix for that. 9_9
https://linustechtips.com/topic/689276-insane-bf1-cpu-usage-fix/#findComment-8846408
I don't really know what your trying to say
System
  • CPU
  • Motherboard
    Asus Z270 PRIME - A
  • RAM
  • GPU
  • Case
    NZXT S340 RED
  • Storage
  • PSU
    EVGA 650W GQ
  • Display(s)
  • Cooling
    CORSAIR H100I GTX
  • Keyboard
    CORSAIR K70
  • Mouse
  • Operating System
    Windows 10 PRO
https://linustechtips.com/topic/689276-insane-bf1-cpu-usage-fix/#findComment-8846559
BF1 has really bad DX12 implementations with terrible frame pacing on literally every gpu.
bf1-benchmark-4k-dx11
bf1-benchmark-4k-dx12
AKA. Cap your fps to your monitor and don't use DX12. It isn't better in any way shape or form for ANY gpu.
http://www.gamersnexus.net/game-bench/2652-battlefield-1-graphics-card-benchmark-dx11-vs-dx12
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/689276-insane-bf1-cpu-usage-fix/#findComment-8846603
OP's other thread
In this thread, looks he enabled DX12, CPU is now not hovering at 100% as before, but the first 3 minutes the game stutters. After that everything runs fine, is there a fix for this? IMO it's not even a actual problem. Now if that was a problem, the priority of fixing it will be so low, it might take a while until there is a patch for it.
If the game runs fine for the first 3 minutes and then it stutters, then it's a real problem.
3 minutes of smooth game play, then it stutters, fix priority #1
3 minutes of stuttering, then smooth game play, fix priority #100
https://linustechtips.com/topic/689276-insane-bf1-cpu-usage-fix/#findComment-8846621
Just now, NumLock21 said:
OP's other thread
Basically I'm saying it is a real issue that might be worse in the first 3 min, but will continue to be bad continuously and dropping cpu usage (which is not inherently bad) because it's just worse (literally in every possible situation the DX12 solution has worse frame pacing and performance) is a bad solution.
https://linustechtips.com/topic/689276-insane-bf1-cpu-usage-fix/#findComment-8846628
HIs other thread was concern about why his cpu is at constant 100%. This thread seems he might have fixed that issue, by switching to DX12, but now he has another minor issue, where he's stressing about it as well.
And I know DX12 isn't that good with BF1
https://linustechtips.com/topic/689276-insane-bf1-cpu-usage-fix/#findComment-8846639
1 minute ago, NumLock21 said:
HIs other thread was concern about why his cpu is at constant 100%. This thread seems he might have fixed that issue, by switching to DX12, but now he another minor issue, where he's stressing about it as well.
I'm saying the "fix" is the issue. That going back to the "not-a-real-issue" is the solution. That and enabling a frame rate cap.
https://linustechtips.com/topic/689276-insane-bf1-cpu-usage-fix/#findComment-8846644
It was mentioned in the other thread. I guess he might have missed it.
https://linustechtips.com/topic/689276-insane-bf1-cpu-usage-fix/#findComment-8846661
See the thing is I don't want a frame cap. I just want to be able to play the game without any restrictions and I didn't buy this system for the CPU to bottleneck.
System
  • CPU
  • Motherboard
    Asus Z270 PRIME - A
  • RAM
  • GPU
  • Case
    NZXT S340 RED
  • Storage
  • PSU
    EVGA 650W GQ
  • Display(s)
  • Cooling
    CORSAIR H100I GTX
  • Keyboard
    CORSAIR K70
  • Mouse
  • Operating System
    Windows 10 PRO
https://linustechtips.com/topic/689276-insane-bf1-cpu-usage-fix/#findComment-8846675
There will ALWAYS be a bottleneck somewhere if you let the framerate go as high as it wants to and Battlefield games can be hard on CPUs.
https://linustechtips.com/topic/689276-insane-bf1-cpu-usage-fix/#findComment-8846755
I have no bottlenecks in gta v and other CPU intensive games. And the fps is uncapped.
System
  • CPU
  • Motherboard
    Asus Z270 PRIME - A
  • RAM
  • GPU
  • Case
    NZXT S340 RED
  • Storage
  • PSU
    EVGA 650W GQ
  • Display(s)
  • Cooling
    CORSAIR H100I GTX
  • Keyboard
    CORSAIR K70
  • Mouse
  • Operating System
    Windows 10 PRO
https://linustechtips.com/topic/689276-insane-bf1-cpu-usage-fix/#findComment-8846764
The limiting factors is likely from a component you're not measuring.
An uncapped framerate means the PC will keep rendering faster and faster till something hits 100%.
https://linustechtips.com/topic/689276-insane-bf1-cpu-usage-fix/#findComment-8846781
What do you mean component I'm not measuring?
System
  • CPU
  • Motherboard
    Asus Z270 PRIME - A
  • RAM
  • GPU
  • Case
    NZXT S340 RED
  • Storage
  • PSU
    EVGA 650W GQ
  • Display(s)
  • Cooling
    CORSAIR H100I GTX
  • Keyboard
    CORSAIR K70
  • Mouse
  • Operating System
    Windows 10 PRO
https://linustechtips.com/topic/689276-insane-bf1-cpu-usage-fix/#findComment-8846848
There will always be a bottleneck somewhere. Something will eventually hit 100%.
Saying that gta or watchdogs or pong doesn't have issues means absolutely nothing. Different games are different. Just because two games are cpu intensive, doesn't mean that they should perform identically.
You have your solutions. If neither of them appeal to you, then you should get a hold of ea. There's nothing that anyone can do for you here that wasn't covered in the 60 or so replies in both your threads.
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
https://linustechtips.com/topic/689276-insane-bf1-cpu-usage-fix/#findComment-8848206
  • 7 months later...
On 11.11.2016 at 6:08 PM, zJordan said:
because there are still microstutters here and there and if i have an overclock i5 i also want to get constant 120fps and not 60fps on 35% gpu usage. GPU optimization is always awesome in Battlefield games but the CPU requirements just suck. And the thing I dont get is that SW Battlefront uses the same engine with the same graphics and there i get a constant 90-100% gpu usage and 140 fps on maxed out settings which is really smooth
