Recovery Experts
Okay so I managed to get my data back.
I'll be explaining what happened. So basically, I have my mass storage device (WD Green 2TB) partitioned 3 times. One for Linux, one for Windows, and one for Mac. The issue is when things went wrong with the mac partition. Storing all 3 partitions on the same drive isn't the problem. Things went wrong when I was encrypting the Mac partition. The way that I encrypted the Mac partition was right clicking on the drive in OS X and selecting the encrypt option. (Basically the default method for encrypting something in OS X as far as I know. ) It successfully encrypted the partition. However, doing so, I was unable to access my Windows and Linux partitions when I rebooted back into the Windows and Linux operating systems. I thought that I had lost all of my data because the encrypting process was taking such a long time for the Mac partition that I thought something went wrong or something wasn't responding correctly etc... I decided to hard restart the system to see if that did anything. Even when the encrypting of the Mac partition wasn't finished, I was still able to access my Mac partition's data fine. So I figured everything went okay. After the system booted back up in OS X, the Mac partition was still encrypting. I decided to see if letting it finish did anything or not so I just let it sit there. It finished and that's when I decided to boot back into Windows. That's when I realized I wasn't able to access my Windows partition and the data. I figured I wasn't able to access the Windows partition of the drive because I fucked up the encryption process by hard restarting the system. Turns out, this was not the case. When I encrypted the Mac partition it turns out that doing so, the encryption process for Mac revoked rights for myself to access the Windows and Linux partitions on Windows and Linux OSes. So that's when I started freaking out (obviously at this point I thought I was fucked).
After freaking out for a while, I thought maybe decrypting the Mac partition would reverse the whole situation. Not exactly.......... You would figure that it would be fine after doing so but I guess not?....... It seems as if the Mac encryption process creates a dedicated protective partition or something? (See images) So I had a look in Disk Management in the Windows side of things to see what was going on. Looked pretty okay until I saw that my entire Linux partition was recognized as unallocated space. So when I saw that I was thinking that the data is so horribly corrupted that it doesn't even see the 3rd partition correctly.
So I'm out of ideas and my thoughts are that my data is so horribly corrupted that there is going to be no chance of recovery at all. When I was in the Mac OS, I noticed that it still saw that all 3 partitions were there which was interesting, but I wasn't able to access the two of them. I booted into Linux to see what it saw and it actually saw the Linux partition, but it said that I didn't have permission to access it. After that, I decided to install VeraCrypt for Mac to see if that did anything. Maybe it would be able to see the Windows partition somehow? Luckily, it found the Windows partition (that's where 99% of my data was by the way) so at this point I couldn't fucking believe it. Did not expect such an idea to work, but there I was and it was there.
Currently have my Windows partition now backed up/on a different PC until I can get a backup dedicated drive for my desktop. Doesn't look like I'll be able to get the Linux partition or any data there back, but I don't really care because I didn't have much on there anyway. The Mac partition is still intact and I'll get my Mac files off there soon.
