Low End Liquid Cooler
Solved by rn8686,
1 minute ago, Sha Bla Wo said:the fans look ugly with the beige and brown colour, and I don't feel like spending money to get black and white ones
You could get the pro version (Dark rock pro 3) or look at the Cryorig R1 Ultimate if you are that worried about aesthetics (I personally dont care about the fans). How much are you overclocking? Unless trying to push it to the max, slightly cheaper air would work fine. Going back the Dark rock 3 or Cryorig H5 perhaps. Just know that these coolers may not perform quite as well as Noctua with temps and acoustics.
