My first build. Will this work pretty well and are the pasts good together?
you do not need a hyper 212 since you are not OC and that cpu comes with a stock heatsink
CPU-i7 6700k O.C. 4.6Ghz-Motherboard-Asus z170-a-RAM-24gb DDR4-GPU-EVGA GTX 1080 FE-Case-Corsair 400c (white)-Storage-HDD: 2xWD Blue 1TB SSD: PNY SSDSC120GLC709B121-510 120GB-PSU-1000 watt coolermax-Display-ASUS VG248QE Black 24" 1080p 144 Hz -Cooling-Corsair H115i-Keyboard-G.Skill KM780 Cherry MX blues (Red backlight)-Mouse-Logitech G602-Sound-Logitech 5.1 z506
Need a budget headphone for under 100$? Sennheiser HD 558 Headphones
Got a Skylake CPU (k) Here is a guide to OC it!
Scrap that cooler and get a RX 470, you don't need one intel includes one with the box. Also get a 450W CXM, 650W is plain unnecessary with a RX 460 and even a RX 470.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
4 minutes ago, Striker123987 said:
The cooler may not be necessary, but it is a great cooler. It wil keep your system quiet and cool. If you aren't a tight budget, I'd keep it. Also a cheap SSD will make a big difference for about $60. PNY CS1311 240GB or the OCZ Trion 150 240GB are good options. Highly recommend. A better card wouldn't hurt either, but its is fine.
My System:
Intel Core i5-4690k  / Cooler Master Hyper 212 Evo Asus Z97-AR MSI Nvidia GeForce GTX 970 100me Corsair Vengeance LP 1600Mhz 2x4GB DDR3 Samsung 850 EVO 250GB / Seagate Barracuda 1TB 3.5" 7200RPM HDD / NZXT S340 EVGA SuperNOVA G1 650W / Windows 10 Home 64 / AOC G2460PQU 1080p 144hz / Corsair VOID Wireless RGB Razer Taipan Laser Razer Blackwidow Ultimate 2014
My Laptop (Asus X55C-DS31):
Intel Core i3-2370M @ 2.4Ghz 6GB RAM / OCZ ARC100 240GB SSD /
My Phone:
OnePlus Three Graphite Black / 64GB
My Watch:
Moto 360 1st Generation
But if that means getting a much much slower RX 460, you are better off with the stock cooler. You can get another cooler later.
You do know the cheapest RX 470 is $175 right?
Not to mention its a stock cooler one
26 USD saved by getting a 450W CXM and 30 USD saved by getting the stock cooler, so total 56 USD saved. Add that to the price of the 460 he is getting and you get 183 USD. Enough to get a 4GB 470, is not?
For best build, I would drop the cooler (at least temporarily) , but I'd buy a SSD. The Corsair CX430M can be bought for cheap, I would also recommend getting the 470. (make sure if you buy a 430M you have the included 8pin GPU power, because you cannot buy a random one, You must have the cable designed for it.
My System:
My Phone:
My Watch:
1 minute ago, Castdeath97 said:
26 dollars saved by getting a 450W CXM and 30 dollars saved by getting the stock cooler, 56+127=183. Enough to get a 4GB 470, is not?
Plus the fact you only said about the cooler
And the RX 460 is $100 not $127
Sort of the same as everyone else ....
- you don't need a CM Hyper 212. Use the stock cooler and put the money towards getting an RX 470.
Or, if you want the "look" of a fancy cooler, get a cheaper CM Hyper 101i, TX3, 103, etc.
- 650watts is not necessary. Get a CX450M or CX550M instead.
A sieve may not hold water, but it will hold another sieve.
i5-6600, 16Gigs, ITX Corsair 250D, R9 390, 120Gig M.2 boot, 500Gig SATA SSD, no HDD
Did you click the link to his build?
https://pcpartpicker.com/user/Striker123987/saved/#view=smq3CJ
He is getting the 4GB RX 460, specifically this one:
https://pcpartpicker.com/product/JMVBD3/gigabyte-radeon-rx-460-4gb-windforce-oc-video-card-gv-rx460wf2oc-4gd
Costs 127 USD.
Actually, many cards come with a MOLEX to PCIe adapter, and they can be purchased separately (if your power supply doesn't already have a PCIe 6+2-pin connector).
Costs 127 USD.
Costs $100 with MIB
Why do you think we include builds with MIB
Just a little janky and I wouldn't recommend it, but yes.
My System:
My Phone:
My Watch:
Costs $100 with MIB
What do you mean by MIB?
Regardless, if he can afford to pay 126 USD for this card, he can afford to pay 183 USD for a RX 470 if he gets rid of that unnecessary cooler and gets a more suitable PSU to up his budget for the card.
Mail in Rebates. I wouldn't count on them. Never got my $25 from MSI. I did get $5 from corsair tho
My System:
My Phone:
My Watch:
Well the OP is going to pay that 126 USD amount anyway with the mail in rebate, so unless he really needs that 30 USD back there is no reason why he couldn't get that RX 470.
Regardless, that's up to the OP.
Updated
Would like to somehow make this a little cheaper because I am still needing a monitor.
https://pcpartpicker.com/user/Striker123987/saved/#view=xQZf7P
1 hour ago, keNNySOC said:
Costs $100 with MIB
Just now, Striker123987 said:
Updated
Get a cheaper RX 470 like that one:
https://pcpartpicker.com/product/FgBrxr/xfx-radeon-rx-470-4gb-triple-x-video-card-rx-470p436bm
3 minutes ago, Castdeath97 said:
Ok then last question for now. All of this would fit nicely in the case and do you think you could tell me some games I could run on high? The games I try to play right now are Rocket League, H1Z1 KotK, CSGO and would like to play bigger games even. This is just what I am worried about the most is not being able to play the games I want on good settings with good frames.
most definitely even with a 460. I still recommend getting a SSD tho.
My System:
My Phone:
My Watch:
Probably can completely max these out
For more on RX 470 performance:
I think the RX 470 should have had a price drop to 169, but for some reason some of the cards still sell at 180ish
