I use one, doesn't does much for me though as a PhysX card.
CPU: AMD R7 5800X | CPU Cooler: Corsair H115i PRO | Motherboard: MSI B550-A PRO | Memory: G.Skill RIPJAWS V DDR4 3200mhz 64GB | GPU: EVGA RTX 3080Ti FTW3 Ultra | PSU: Seasonic Prime 1300w | OS Drive: Samsung 850 EVO SSD 500GB | Games Drive: Samsung 850 EVO SSD 1TB | Media Drive: 2x WD Blue HDD 1TB in Raid 0 | Media Drive: 2x WD Black HDD 2TB in Raid 1 | Case: Corsair Obsidian 750D | Monitor 1: ASUS PB287Q UHD | Monitor 2: ASUS PG278Q WQHD
Does it make any difference at all for you? I have a gtx 750 lying around that I am tempted to use for physx. Scared it'll do more harm than good.
Main Rig: CPU i7-4790k / MOBO Asus Z97-Pro (Wifi-AC) / RAM 16GB HyperX Fury 1866 MHz / CPU COOLER Dark Rock 3 / GPU Asus GTX 1070 Strix  / CASE Evolv ATX Tempered Glass / SSD Crucial MX200 250GB / HDD  WD Black 1TB + WD Blue 3TB / PSU EVGA 750G2 / DISPLAYS 2x Dell U2414h / KEYBOARD Corsair K70 RGB Cherry MX Brown / MOUSE Logitech G602
Laptop: Dell XPS 15 / i7-6700HQ, 16GB RAM, 512GB SSD, GTX 960m, 1080P Display
Cheap Windows/Office Keys
Reason I ask is because I play a lot of borderlands which uses and gets rekt by physx.
Well the lsit of games that support phys X are pretty low
My life
5 minutes ago, Thunder_Ruler0 said:
Just curious if people actually use a dedicated PhysX card like me.
I used my 970 as a PhysX card with my 1080 for a while but I found that it just made the 1080 a little too hot so I took it out. Didn't notice a frame difference anyways
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
it does for me. up to 20-30 frames. but it all depnds on what game you are playing, and if it uses physX
Dell XPS 15 9570 w/ ThinkPad T430
Borderlands 2?
Borderlands 2?
Does it have the option? Also I was referring to Metro 2033 for me. I dont see a reason why you wouldnt pop in another GPU if you have space, and another one laying around doing nothing. You can use it for rendering (like me), more ports (also like me), and physX. Just for the cost of a few more watts depending on the card.
Yea it has the option. I don't think it will make much of a difference though. My GTX 1070 is rarely working above 50% load yet my frames drop below 60 all the time. I might try it one day if I have nothing better to do.
Ah, I see. I think this is mostly due to the game, or some bottleneck inside your system. I have a similar issue with Gmod where my GPU is locked at %10 and I get anywhere around 40-80 FPS though I have no idea as to what may be causing this. There are people with 200-400 FPS with the the same configuration. So I don't know as to what may be causing this.
when i make my first game, it will not have physx, it will use openCL physics engine, so dont count on physx.
I've used dedicated physx in the past and in various odd ways and i can tell you that while it is nice it makes it unfair because you have to look at the various platforms out there. All 3 GPU brands (intel IGP, nvidia, AMD) all support openCL and many systems having IGP + dedicated means you can make use of the IGP for running some code.
You also have to look at other platforms. Consoles now all use AMD, dont think physx matters there. the PS3 even though it had nvidia GPU used its own cell CPUs to calculate physics and 3D and even the ps3 can run openCL. Tablets, phones, ultra portables, nvidia isnt the leader here, most of the market is filled with various implementations but what they all have in common is that many of them can run openCL as the powerVR GPU and even qualcomm's own snapdragons can run it but usually with games they will be bogged down with graphics work without any free resources for physics.
So what physx gives is very narrow to what a custom openCL based physics engine could support even if the performance may be lower.
I've tried having a card dedicated to physx before but i dont anymore. At first i used an eGPU with my laptop, the GTX 580 doing graphics while my laptop's onboard quadro doing physx and the performance was bad due to the PCIe x1 slot. Batman arkham asylum was a well optimised game that i would get above 40fps on a core2 laptop using the GTX 580 for physx. And than i had a GTX 285 in a desktop doing physx with AMD graphics using some sort of hack. Didnt play many physx games though but the GTX 285 did quite well in fluidmark with AMD doing the rendering.
Currently havok is much more widely used than physx as not only does havok take advantage of the SSE instruction sets but is also used on consoles too and isnt limited to hardware from on manufacturer. Less games use physx because not only is it restricted to nvidia cards but it will only let you use it if you also use nvidia for rendering. it is also still unoptimised on x86 so it doesnt make it makes it expensive to adopt as your console and PC game versions will be very different and expensive to create and maintain.
For running physx on the same GPU the GPU architecture needs to be compute focused (Fermi, pascal, not kepler) supporting better context swapping (stuff like good branching performance, etc) things that CPUs are good at. For running physx on dedicated GPU this does not matter. You should have a good amount of PCIe lanes ( SLI bridge is unfortunately not used for physx) and system ram bandwidth as with physx on dedicated GPU the GPU does not directly swap data from one GPU to another (all GPUs are capable of this but nvidia only allows this feature on their tesla line). This means that physx data has to be taken from the 2nd GPU, put into ram and transferred to the main GPU.
So many limitations with physx that it just doesnt take advantage of what there is available in hardware.
I can say the same. Although PhysX is something that can easily be replaced with other languages and such. The whole point of the post was to see how many people actually use a dedicated card. And don't think that I am bashing down on you for not just giving a simple answer, you have plenty of points that i see why many people can agree with. The only reason I ask is because besides the advantage of using another GPU for extra ports, rendering power, etc. If you were on an older system running a 570 per say. If you played a game like metro 2033, and turned on the PhysX settings, it would (in some places) consume a whopping %20-30 of the GPU. Sure, its not necessary to play the game, and its mostly just for fancy affects, and other things. Simply having another GPU (supposedly Nvidia of course) you can pop it in an increase your FPS in certain games using your old GPU and giving it a new task.
   So, I guess the point is that if you want those extra frames then you could always pop in another card for PhysX in games that support it. Though limited, and not many games use it now these days. Its still nice to have an option to dedicate some things to another GPU to help take some stress off the main GPU, unless your doing SLI of course.
    And one last thing. I guess one of the main reasons as to why consoles use AMD instead of Nvidia, is more of the level of it generally being cheaper and sometimes better to Nvidia card equivalents. But, based on what I believe. I think Nvidia has more of the software down then AMD, but that could just my opinion.
I tried it, doesn't do a thing for the games I play. 0% usage out of the other card all the time.
Well, not all games have PhysX. And if they did, you would need to enable it.
Thus why it was pointless.
6 minutes ago, Thunder_Ruler0 said:
All a matter of opinion, and what you plan on using the second GPU for. I explained it on one of the comments above.
It isn't an opinion if I have a second card dedicated to physx and none of the games I play support it, it is in fact useles.
I'm saying the fact if having another card in your system is useless. Please read again.
