Should I replace Thermaltake Suppressor F51 stock fans?
kingmustard
I have a Thermaltake Suppressor F51.
It comes with the following:
Rear fan
Presumably non-PWM
140mm, 12v, 3.5w
1000±200 RPM
50 CFM
0.3mm H2O
16 dBA
Front fan
Presumably non-PWM
200mm, 12v, 2.4w
800±200 RPM
130 CFM
1cm H2O
13-15 dBA
Do you think they're worth replacing? Maybe with PWM fans?
6 minutes ago, kingmustard said:
Presumably non-PWM
PWM just means you can run it at lower RPM than non-PWM, and you can tell by looking at the fan connector and counting the pins. 4 pins? PWM. 3 pins? No PWM.
As for replacing the fans, you need not they will work just fine.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
PWM really doesn't matter unless you want very low RMPs. Unless they're annoyingly loud I see no reason to replace those.
Lenovo Ideapad 720s 14 inch ------ One day I'll have a desktop again...
Agreed, If it ain't broke, don't fix it.
As long as the temps seem normal for your rig I wouldn't change it.
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
Why not run them for a while first and see if they're able to keep your CPU cool under load without screaming like Deltas praying to the airflow gods?
I'm not entirely sure what model the rear fan would be, but I can tell you that the 200mm front fan can run as low as ~200 RPM and is damn near silent up to about 600-700 RPM. Even at full speed, it's more of a low-pitched hum than typical high-pitched fan noise, and it remains quiet. I had one plugged directly into the PSU for a while with a 7V adapter on it, and didn't hear it at all from about 24 inches away.
If there is such thing as a 200mm PWM fan, I've never seen it.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
Replace them for what reason? Are you finding the noise excessive or performance lacking?
