DVI-D and Display Port
Guest
I'm currently working on my first PC build and was wandering if there is a difference between DVI-D dual-link and Display Port. I have a monitor which I have been using for a while, and it supports 1080p at 144hz. But it doesn't have a display port input. Is this a big deal as it means I may have to get a new monitor.
Dual link DVI is capable of 1080p@144hz. So if your gpu has a dual link dvi output then it's fine. (and if it doesn't have a dual link dvi out, then you can just get an active dp to dual link dvi adapter).
PSU Tier List | CoC
Gaming Build | FreeNAS Server
5 minutes ago, Electronics Wizardy said:
It won't make a difference. There both digital and show the exact same image and frame rate.
Do they both allow for audio?
I plan on getting either the gtx 1080 or 1080 ti.
1 minute ago, Electronics Wizardy said:
Only displayport has audio
DVI can also carry audio, but it begs the question why....Monitor audio sucks anyway.
PSU Tier List | CoC
So how would I get audio with dvi? I use a headset 95% of the time, so does that mean I would use the headphone jack on the PC rather than the monitor?
So I'm fine as long as I use the audio from the PC not the monitor? I'm gonna be using headphones 95% of the time anyways.
yes
PSU Tier List | CoC
yes
Thanks. You just saved me a quite some money and effort
Yep. You probably also get better audio quality from your pc directly.
Thank you
