Hey guys,i recently bought an hdmi cable because i was using my very old vga cable with a dvi adapter and the image is worse.Im using a tv as a monitor which has a 1680x1050 resolution.I reinstalled drivers,I put the scalling option to 0%,i put the color pixel format as full rgb,i changed refresh rates and resolutions but still nothing changed.I changed the hdmi channel of my tv to PC and more types.I tried the hdmi 2 channel but still didn't work.However,I noticed that my tv shows 1080p resolution on the hdmi channel while im using 1680x1050.I can't even see when i use dots in this text.Any advice?
Cpu:Athlon ii x4 750k,Gpu:Sapphire hd 7770,Mobo:AsRock fm2a75m-dgs,Psu:Corsair cx430,Ram:Crucial ballistix 2x4gb,Case:Zalman z9 plus,Hdd:WD blue 1TB 7200rpm,Mouse:Cm storm Xornet,Keyboard:Sharkoon Skiller,Headset:Plantronics Gamecom 380,OS:Windows 7 64bit
https://linustechtips.com/topic/67416-blurry-screen-with-hdmi-cable/
If the tv supports 1080p through HDMI (which I'm sure it does) then change your desktop res to 1080p. I run a 1080p monitor (vga as I can't find my DVI cable yet) and my TV (40" Toshiba) through HDMI in Mirror Mode.
MOBO - Asus Sabertooth 990FX R2.0   CPU - AMD Phenom II X6 1055T @ 3.5GHz - Corsair H80i   RAM - 2x Corsair Vengence 4GB DDR3 @ 1666 MHz
GPU - SAPPHIRE 100362-3L Radeon R9 290 4GB Tri-X OC  Sound - ASUS Xonar DSX  PSU - Thermaltake SMART M Series SP-850M 850W
First of all, with HDMI cables, you either get a signal or you don't, there is no in-between, it will work or it won't.
Since its working, there is nothing wrong with your cable, its your TV.
Could you post which TV you have?
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
I really don't know if it supports 1080p.The tv is supposed to have 1680x1050 resolution.If im using the vga cable nothing is blurred but if i change the resolution to 1080p i can't see everything on the screen.And no,if i change resolutions nothing changes
Yep,i know that hdmi cables are not divided between bad and good cables.I mentioned in the title and in my the post hdmi because when i use my vga cable it works just fine.It is a thomson 22E92NH22
Maybe change the sharpness/smoothness on the tv? I know mine varies on connection/channel. Adjust your tv phase if you can as well.
I had the same problem where my tv was blurry at (1320?)x720 (16:9) but at 768 it was the best picture I have seen.
I tried and it didn't change anything.I still don't know why the info about the hdmi channel of the tv says 1080p in pc mode.I'm using only 1680x1050
Could you list your computer specs? Would also help to know if you're using a desktop pc or laptop.
Might have an over scaling problem!
work it ᕙ༼ຈل͜ຈ༽ᕗ harder, make it (ง •̀_•́)ง better, do it ᕦ༼ຈل͜ຈ༽ᕤ faster, raise ur ヽ༼ຈل͜ຈ༽ノ donger
ᕙ༼ຈل͜ຈ༽ᕗ HARDER, BETTER, FASTER, DONGER! ᕙ༼ຈل͜ຈ༽ᕗ
Athlon x4 750k,asrock fm2a75m-dgs,amd hd 7770.
Nvm guys,i will just use my vga connection.
your a genius.. i've been using my tv for over a year and 1920x1080 always didnt fit the screen even though its a 1080p tv.. just checked my tv's option and overscan was on. problem solved...
haha well glad i could help! :P
